2002 Explorer IRs Track width
Old Oct 17, 2010 | 06:01 PM
fittyfod's Avatar
fittyfod
HI can anyone tell me what the 2002 Explorer track width might be? I cant seem to find that anywhere.
Also want to confirm its 5 on 4.5 bolt pattern and has an aluminum 8.8 or 9.75 center section.
Looking to swap this into my 1950 ford F1.
thanks
b
Old Oct 17, 2010 | 08:23 PM
ncranchero's Avatar
ncranchero
Bolt pattern is 5-4.5 and the rears will be 8.8's. Track Width (front/rear) 60.9 / 61.2 & axle ratio codes are
41 — 3.27 ratio, non-limited slip.
43 — 4.30 ratio, non-limited slip.
45 — 3.55 ratio, non-limited slip.
D4 — 3.73 ratio, limited slip.
44 — 3.73 ratio, non-limited slip with interactive vehicle dynamics (IVD).
Old Oct 17, 2010 | 08:41 PM
85e150's Avatar
85e150
Overall width was 72.1 inches, so the track should be approx 60-62 inches---???
Old Oct 18, 2010 | 08:23 AM
06silvercrew's Avatar
06silvercrew
Why not use a mustang or thunderbird etc rear end? They come out as an entire unit, sub frame and all, where the exploders are not.
Old Oct 18, 2010 | 09:26 AM
fittyfod's Avatar
fittyfod
I have the lincoln mark8 irs. Someone mentioned the explorer because its already the bolt pattern I wanted and most likley had the center section specs I need.
I am having the lincoln hubs machined. I also narrowed the entire lincoln subframe 4 " so that I can get the track width I need.
So the explorer is not on a subframe? Well now I dont feel so bad...
Old Oct 18, 2010 | 11:43 AM
06silvercrew
Yeah all the explorer control arms etc mount the the full frame structure. Couple weeks ago the guys on the TRUCKS! TV show put a cobra IRS on a ranger frame, was pretty trick!
Old Oct 18, 2010 | 11:47 AM
fittyfod's Avatar
fittyfod
Yup. I saw that too! I want a cobra irs but very expensive. Those guys are spoiled. Get to do anything and everything without concern for money. Im jealous. Its funny how they will purposly go the low buck route on some projects, but they still have all the tools and resources to do it up.
JTravis1987
Jan 4, 2021 01:14 PM
gogoat
Dec 24, 2015 10:36 AM
dustinwinkle
Apr 17, 2012 12:12 AM
HkyswiM
Feb 4, 2012 11:55 PM
superrangerman2002
Computer Chips & Tuners
Dec 15, 2002 12:08 PM
