mpg reader
Old Oct 17, 2010 | 05:56 PM
wiscvanman's Avatar
wiscvanman
mpg reader
is there an external mpg reader that will plug into the diagnostic port? would like to be able to monitor mileage while driving not after filling the tank.
Old Oct 17, 2010 | 08:31 PM
torkum's Avatar
torkum
Scan Gauge would do the trick. I see their ads around here.
Old Oct 18, 2010 | 09:59 AM
wiscvanman's Avatar
wiscvanman
thanks. didn't know if it would do the mpg.
Old Oct 18, 2010 | 10:25 AM
shotgunz's Avatar
shotgunz
Even if it does, it won't be very accurate.
Hand calculation is the only way to get the real numbers.
Old Oct 18, 2010 | 07:18 PM
galaxie641's Avatar
galaxie641
It is actually surprisingly accurate even with different sized tires and an uncorrected odo/speedo mine is almost spot on. There is also now another box just like the scan gauge but costs about 1/4 the price, can't remember the name now but I will look.
Old Oct 19, 2010 | 05:39 AM
shotgunz's Avatar
shotgunz
If this is the case, then wouldn't it be off by the same % your odometer is off (if you corrected the tire size)?
In other words, if your odometer is off by 5%, then so is your MPG.
rdemarco06
Aug 31, 2016 07:55 AM
FuzzFace2
15
May 21, 2016 09:53 PM
1 Wanderer
Apr 13, 2016 02:24 PM
neilx
Apr 4, 2010 08:03 PM
smoky_diesel
34
Aug 14, 2008 04:45 PM
