SCT Livewire questions
Old Oct 17, 2010 | 07:12 AM
skono's Avatar
skono
I was reading a thread from when the livewire first came out and it sounded like they had some problems with it. I'm assuming they are resolved? With the livewire , I don't need any extra gauges. Correct? Or maybe just exhaust temp.. Is there a decent way to mount it? Would love to see some pics. It looks kind of plain jane compare to other programmers.
Old Oct 17, 2010 | 08:10 AM
tex25025's Avatar
tex25025
Actually some of those issues still haven't been resolved. It seems to be 50/50 on getting a good one. Some also start out as good, but end up showing problems later.
Mainly those problems tend to be screen freezing. Won't turn on or off. Then it would work for a bit and then it'll act up again. I would suggest getting the tried and true X3 and then get a standalone digital gauge(DashDAQ, Insight, Scan Gauge etc).
Old Oct 17, 2010 | 08:18 AM
skono's Avatar
skono
Thanks Tex. But where do you put the X3 after its plugged in? I've never seen one in person. Do they do the same except for monitoring?
Old Oct 17, 2010 | 08:44 AM
tex25025's Avatar
tex25025
After you have uploaded the program you(or at least I would) put it in the glove box or somewhere safe, but close. Within the truck at least.
Now the X3 does have limited datalogging capabilities, so it can monitor, but not to the extent that you are wanting to do. I have only done that once with the xCal 2 and that was for tuning purposes.
Old Oct 17, 2010 | 09:19 AM
skono's Avatar
skono
I was just looking at them and from what I understand I can save the factory setting and load which ever tune I want (Econ, Tow,Extreme,) . I would probably never use extreme. Then restore it to factory if needed. I has seen some guys post that Econ. is a waste. Is a custom tune the best way to go?
Old Oct 17, 2010 | 09:31 AM
tex25025's Avatar
tex25025
Yes, custom tuning is the best for our trucks as a whole. Just go with a tune writer that has a good rep. There are hacks out there and that will sour you on the idea of custom tuning if you deal with one of those.
As to if Econ tune is a waste or not, that'll depend on what your goals are. If you want to maximize economy, then I would actually work on improving driving habits before I would go with performance tuning. Now some people claim that they have had better MPG improvements with higher HP tunes versus Economy tunes. Maybe, maybe not. Too many factors involved that it makes it hard to say that tuning alone was responsible for the MPG improvement.
However, if you are wanting just a little bit of a bump in HP/TQ, but more tweaking on the tranny shifting etc, then the Econ tune might be the best thing for you. It depends on what your goals are. That's the beauty of custom tuning. To further illustrate that, there has been a group of people, albeit very very very small minority group, that has actually detuned their trucks from the factory HP/TQ output.
Lots of options.
Old Oct 17, 2010 | 09:34 AM
jdadamsjr's Avatar
jdadamsjr
Absolutely the ONLY way to go
and u say you won't use extreme ---- talk to me in 6 months
you'll never run without it !!!
the hi hp tunes are said to be the most efficient !!!
Old Oct 17, 2010 | 09:36 AM
skono's Avatar
skono
I appreciate the input. I'm still saving so I,m researching now so I don't jump into something that I won't be happy with in the end.
