Quick lift question.
Old Feb 24, 2003 | 10:14 AM
Screamin T/A's Avatar
Screamin T/A
I have a 1979 F250. I am planning to run 33-35 inch tires and doing some moderate off-roading. I do not want to spend a lot of money for a lift kit though. I was wondering if i could get a 3" body lift and run front and rear add-a-leafs. Would this be cheaper than buying a rough country 4" lift? ($500). Also with this new idea would i need to change my pitman arm, shocks, etc.? thanks in advance.
Old Feb 24, 2003 | 10:32 AM
mudder trucker's Avatar
mudder trucker
just cut the front fender lips, the back will be fine the way it is. i run 35,s on a 79f250, all stock. mudder trucker.
Old Feb 24, 2003 | 12:52 PM
fordguy76's Avatar
fordguy76
go ahead and do the body lift if you're going to do any off roading with 35s that should be enough for them. if you just put extra leafs around it you shouldn't need any of that other stuff.
Old Feb 24, 2003 | 01:31 PM
Screamin T/A
If i get a suspension lift all I would be gaining is wheel travel right? Also, with a 3" body lift you guys think I would be able to fit 35's under there without a problem?
Old Feb 24, 2003 | 10:53 PM
rdnck344's Avatar
rdnck344
Dont waste money on a body lift. Hockey pucks are 1" thick and they do the same thing if you drill a hole in the center and get longer bolts.
Old Feb 24, 2003 | 11:16 PM
Superdave's Avatar
Superdave
Screamin T/A, You will gain body height with a suspension lift also. Whatever the advertised height of the suspension lift is, you will gain nearly that in body height.
It depends on whether new springs are used in the lift kit.
Old Feb 26, 2003 | 08:41 PM
ST_Wilson's Avatar
ST_Wilson
Screamin you will NOT gain wheel travel at all if you just do the body lift, your axles will be the same distance from the frame and bump stops. The only thing you get out of a body lift is increased distance from the tire to the body. You will have to consider stretching the clutch linkage if it is a standard transmission, the steering column shaft to the steering gear box may need lengthening, your shifters may be hard to reach without extensions... etc.
