I'm freezing!!
Old Feb 26, 2003 | 12:57 PM
oft's Avatar
oft
I'm freezing!!
my heater stopped working . Of course this could not happened in June it has to happen in February. When I'm going fast I get heat but no fan. I thought it was a power problem but I noticed the fan would kick on sometimes under hard acceleration. FYI, the truck has air conditioning (not hooked up).
Thanks
Jayson
78 F100
Old Feb 26, 2003 | 01:04 PM
okiebronco's Avatar
okiebronco
I'm freezing!!
my friends did something similar.turned out it was just the ignition switch tho. it wasnt the acceleration that actually did it in his case. altho it seemed like it. it was actually the bumps in the road that jarred the truck. once he changed the ingition switch. it never did it again for the 2 years its been on the road
Old Feb 26, 2003 | 01:16 PM
Crowbar65's Avatar
Crowbar65
I'm freezing!!
Could also be the fan chassis ground, as stated above, makes good contact when the truck gets a good bumping and turns on.
Had it happen to me.
Old Feb 26, 2003 | 02:02 PM
oft's Avatar
oft
I'm freezing!!
So you don't think it's a vacuum problem? what does the ignition switch have to do with the heater?
How would I test for power?
Jayson
78 F100
Old Feb 26, 2003 | 02:11 PM
m1tommy's Avatar
m1tommy
I'm freezing!!
Sir, When my '83 F-150 fan stopped, I replaced the switch. It cost about $20 from a dealership (in '91) and an afternoon of my time. Do NOT drop the control unit on the floorboards, or you'll spend a looooong aftrnoon reassembling all those linkages, springs and ***** in their detents! After I got that back together, I noticed that the switch could have been removed without removing the entire control assembly.....
Or, perhaps do like my dad w/ his '66 Chevy truck: drill a small hole in the fan motor huosing and squirt WD-40 in it. It worked for 20+ years, but did stink some.
HTH,
Tommy
Old Feb 26, 2003 | 02:47 PM
76_390FE's Avatar
76_390FE
I'm freezing!!
The ignition switch doesn't control the fan motor...I would check the wiring, especially the little brown plug right up by the fan motor. Maybe it came unpluged just a bit.
Old Feb 26, 2003 | 07:59 PM
ST_Wilson's Avatar
ST_Wilson
I'm freezing!!
The ignition switch controls when the accessories get power, sometimes the contacts wear out in the switch or the wires work out of the housing or harness.
Old Feb 26, 2003 | 08:51 PM
oft's Avatar
oft
I'm freezing!!
Doesn't sound like it'll take me 5 minutes and its fixed.
Jayson
78 F100
maxtruck00
Jun 17, 2014 08:51 PM
CdnWillyG
Aug 11, 2012 09:13 PM
KevinGnWV
West Virginia Chapter
Nov 15, 2011 03:32 PM
welfarewagon
May 16, 2011 03:03 PM
dsrtjeeper
Apr 27, 2011 11:06 AM
