help!!
Old Oct 18, 2010 | 06:57 PM
TheKirbyMan's Avatar
TheKirbyMan
I -think- that's normal. I believe you're supposed to get 12V in START, ~6V in RUN. How did you go about testing it? I ask so that I can check mine and see if I get the same reading. Everything on mine is operating properly, so it'd be a reference.
Examine the wires going to the coil and distributor too. See if any of them are cut, worn through, burnt, etc.
Old Oct 18, 2010 | 08:22 PM
dangolbadangdang's Avatar
dangolbadangdang
i just used a normal volt meter, positive end on the positive terminal of coil and negative to negative of battery, it was around 6.3
Old Oct 18, 2010 | 09:23 PM
TheKirbyMan
Alright, I'll check mine and let you know.
oddfordjunkie
Jul 4, 2014 12:19 AM
mike1589
Feb 8, 2010 07:09 PM
BottomFeeder
32
Jul 6, 2007 03:35 PM
chrono4
1978 - 1996 Big Bronco
Oct 2, 2006 01:01 PM
Psyte
Dec 6, 2004 12:24 AM
