Problem with turning
Old Oct 16, 2010 | 11:54 AM
pittmick's Avatar
pittmick
When I lock my truck (75 f-100 4X4) into 4wheel drive I can barely turn the wheel and it feels like the wheels are about to come off and I hear a moaning sound under the truck. It feels like each revolution of the wheel I am running over a big railroad tie or rock and then it goes over and repeats itself.
What is wrong or needing replaced as I know this is not good. Also even when it is not in 4wheel drive I have noticed I cant crank the wheel all the way or it does the same thing, only not near as drastic. Does anyone know what this might mean>
Old Oct 16, 2010 | 04:56 PM
4x4 Bart's Avatar
4x4 Bart
It sounds like a problem in the power steering pump.
Old Oct 16, 2010 | 05:21 PM
paredneck33's Avatar
paredneck33
it sounds to me like the axle u-joints are frosen and need replaced. common prob. however just remember when you are on dry pavement and locked into 4x4 you will experience binding in the front end.
Old Oct 18, 2010 | 01:03 AM
pittmick's Avatar
pittmick
Its not binding at all, it is more like I am running over a small log on the front end and after Im over it it repeats itself. If I dont crank the wheel at all it is fine except I can at times hear a moaning sound.
Old Oct 18, 2010 | 01:08 AM
big78f150's Avatar
big78f150
binding will cause similar problems. but my bet is the u joints. had an 81 f250 4x4 the drivers side ujoint in the front was wore out and caused it to do that if turned all the way in either direction
Old Oct 18, 2010 | 08:41 AM
thomabb's Avatar
thomabb
Bound U-joint(s) X3.
blackwaterairsoft
Jun 28, 2011 01:52 PM
Ultralarry
Oct 11, 2010 11:46 AM
carysf250
Aug 4, 2009 01:51 PM
Mr.Russell
2004 - 2008 F150
Aug 7, 2008 10:20 PM
CAPTAIN 3747
Dec 8, 2004 08:02 PM
