Thick grease under engine
Old Oct 17, 2010 | 01:37 AM
Visseroth's Avatar
Visseroth
LOL, well sounds pretty general to me because pretty much everything likes from time to time at different places on different trucks, LOL.
But yes, as stated, best to clean it up and back track it, find the source so we can inform you with more detailed advice.
Old Oct 17, 2010 | 10:16 AM
PaysonPSD's Avatar
PaysonPSD
If you have a large accumulation of leaking oil on driver side below the exhaust manifold it could be the oil cooler.
The only illustration of the oil cooler I have, but as you can see it is forward of and connects to the oil filter mount.
After you get it all cleaned up look at both ends of the oil cooler.
Old Oct 17, 2010 | 01:59 PM
natedlee's Avatar
natedlee
You are all great -- really helping me think this through. Thanks.
I am hoping to get to a wash today, but I took off the inside engine cover to also check some clicking noises I am hearing and found that there is definitely some oil collection up top that could be draining down and spreading... another place to clean real well I guess.
The pics aren't that great but sorta show under the turbo and along the right side of the top it looks as though a gasket is leaking -- we'll see.
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/K8Gf81BBS0r2mt066roE5Q?feat=embedwebsite"><img src="http://lh3.ggpht.com/_CeOZErpnF6w/TLtAOTa6TlI/AAAAAAAAXWs/UW-jkMtLOgg/s144/2010-10-17%2018%3A27%3A56%20GMT.jpg" height="107" width="144" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/ndlee1/E350?feat=embedwebsite">E-350</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/Tppmr8SRHg5BdL14zoRNMQ?feat=embedwebsite"><img src="http://lh3.ggpht.com/_CeOZErpnF6w/TLtAR8fUPmI/AAAAAAAAXW4/bIs4Pfat4QY/s144/2010-10-17%2018%3A28%3A07%20GMT.jpg" height="144" width="107" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/ndlee1/E350?feat=embedwebsite">E-350</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/AzOGMbP5xr_q8yOfpLBuKA?feat=embedwebsite"><img src="http://lh6.ggpht.com/_CeOZErpnF6w/TLtAUhYMoDI/AAAAAAAAXXA/XKZKzy6DfcI/s144/2010-10-17%2018%3A28%3A20%20GMT.jpg" height="144" width="107" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/ndlee1/E350?feat=embedwebsite">E-350</a></td></tr></table>
Old Oct 17, 2010 | 02:34 PM
PaysonPSD's Avatar
PaysonPSD
I'm not used to seeing pics of the 7.3 from those angles. But you could have a turbo o-ring or EBPV (Exhaust Back Pressure Valve) actuator leak.
There are 2 o-rings between the turbo pedestal and block, and 2 o-rings between the turbo pedestal and turbo.
The EBPV actuator is located in the bottom front of the turbo pedestal. The EBPV actuator is electrically controlled and hydraulically operated by the low pressure engine lube oil.
Old Oct 17, 2010 | 04:46 PM
mudmaker's Avatar
mudmaker
My guess is the LPOP. The bottom of my motor looks very similar to that. Oil build up all over the steering components, axle and radiator hoses.
Old Oct 17, 2010 | 05:10 PM
Visseroth's Avatar
Visseroth
natedlee, can you shoot a video of everything you see under the truck so we can get a better picture as to what is going on and also around the turbo pedestal?
Old Oct 28, 2010 | 09:16 PM
natedlee's Avatar
natedlee
Crank Seal
So it turns out the Crank Seal is the culprit. My new diesel genious friend tells me it's completely worth fixing and he'll help me in his own garage. Awesome. I guess in the van I've gotta remove the radiator to get his puller in there, but should be a fun project... I think.
So, in the end, the crank seal's leaking and the fan is blowing it all over everything. Makes sense.
Old Oct 28, 2010 | 11:48 PM
Visseroth's Avatar
Visseroth
nice, wonder how hard that is to fix.
DIYiT
22
Sep 27, 2013 11:08 PM
limpysmalls
User Gallery & Picture Display
Dec 11, 2010 07:21 PM
phoenix_bird
Dec 6, 2010 03:57 PM
natedlee
Oct 16, 2010 08:54 PM
ken2400
May 2, 2010 08:08 AM
