Fuel pump shutoff??
Old Oct 15, 2010 | 12:16 PM
ZHMMY's Avatar
ZHMMY
Fuel pump shutoff??
My 1989 F150 6cyl was starting and running fine. Then it was not started for over a month. When I tried to start it the battery was full charge and the starter worked fine but the engine didn't give any hint of trying to fire.
Is there a fuel cutoff reset button, and if so where? I was told the kick panel on passenger side, but nothing there I could find.
Old Oct 15, 2010 | 12:32 PM
polarismuddman's Avatar
polarismuddman
The passenger kick panel is just the location for the 92 and up trucks...yours is under the driverside dash on the firewall.
Old Oct 15, 2010 | 01:16 PM
wickedklown83's Avatar
wickedklown83
pretty much follow your column down behind your brake pedal and it is pretty much right behind it
