View Poll Results: Which gauge do you like best?
Black w/ Spun Aluminum "All American Tradition"
75.00%
Spun Nickel colored Aluminum "All American Nickel"
25.00%
Voters: 4. You may not vote on this poll
Opinions Please...
Old Oct 15, 2010 | 07:47 AM
bluestang65's Avatar
bluestang65
Opinions Please...
I'm going with aftermarket gauges in the Pickup. I've narrowed it down to two different choices shown below. Which do you like and why? I'll use the 5" speedometer that matches the gauge pictured below along with a quad gauge setup. The tach and quad gauge will go in the factory auxiliary gauge holes and will be 3-3/8" as the original tachs were. It should look pretty slick, I just need some help deciding on which one to go with. The black one will get a red pointer rather than white.
1:
2:
Old Oct 15, 2010 | 08:22 AM
Bill W's Avatar
Bill W
i like the second one
Old Oct 15, 2010 | 09:29 AM
66f-100's Avatar
66f-100
The first one with a red pointer will look nice.
Old Oct 15, 2010 | 10:59 AM
truckrod's Avatar
truckrod
I like the first one
Old Oct 15, 2010 | 11:20 AM
CropDusterMan's Avatar
CropDusterMan
I'd go for which matches your gauges the most...personally, I've yet to see an after-market tach that looks good installed...it's great to have the info, but I always feel they look quite ad-hoc. Having said that...the ones you've posted are the nicest I've yet seen.
Old Oct 15, 2010 | 11:34 AM
bluestang65
I'm using the matching speedometer, so it all the gauges will be identical. If I use the black, I'll have them install red pointers rather than the white ones.
Old Oct 15, 2010 | 11:38 AM
bluestang65
Here's a Quad Gauge in the black:
And here's a speedometer in the nickel:
As you can see, the gauge series are nearly identical in design except for the color.
Old Oct 15, 2010 | 11:47 AM
StevenhF100's Avatar
StevenhF100
What color is the interior? The 2nd one would go great with brown to beige interior, 1st better with black or grey. My 2 cents.
Old Oct 15, 2010 | 11:54 AM
tofargone's Avatar
tofargone
It rilly depends on what you are going for the first one is ezer to read at a glance so if your putting it in a daily driver id use that one but the second one is more classy so if your putting it into a show rig or a weakend warrior I would use the second
Old Oct 15, 2010 | 01:01 PM
macgiobuin's Avatar
macgiobuin
I like the black ones.
Old Oct 15, 2010 | 03:42 PM
CooGAR's Avatar
CooGAR
Black! Always a classic.....never goes out of style.
Where are you buying these from (just in case........ )
