Trouble Idling
Old Oct 19, 2010 | 06:42 PM
  #31
75Three90's Avatar
75Three90
well see james a dizzy is driven by the camshaft over a period of time the bottom gear of a dizzy will wear down and it wont turn right and bog and misfire, and this is often confused with a bad pip so they replace the entire distributor and its fixed but it wasnt the pip it was the bottom gear of the dizzy
Old Oct 19, 2010 | 06:51 PM
  #32
f-150_1993's Avatar
f-150_1993
i hear ya its just that its never happened to me. maybe luck? haha
Old Oct 19, 2010 | 07:07 PM
  #33
75Three90's Avatar
75Three90
its happend to me about 4 times but to customers i see it all the time its and easy 100 bucks everytime lol
Old Oct 19, 2010 | 08:56 PM
  #34
subford's Avatar
subford
Originally Posted by f-150_1993
hmm... i think they are trying to trick you into parts. Gotta be careful and that's why you have us. Air pump I doubt needs to be replaced. What do you think subford? I'm okay with the EGR being replaced. Did you go to a mechanic johnstonwg23? I know your getting tired of us saying this but... Check for codes!!! lol
The Air Pump would only need to be replaced if it is locked up and would not turn.
The EGR valve would not have to be replaced unless it has a bad diaphgram.
True it may be stuck open and keeping the truck from idling but it would just have to be cleaned and freed up. The sensor on top may or may not bet bad but you would not know this until the EGR valve is cleaned and freed up.
You could also drop a penny in the EGR tube where it screws onto the EGR valve but do not over tighten it. If the EGR is open the engine would run OK with the penny in it.
I have drove a lot of miles with a penny in mine.
evansz95
Apr 16, 2014 11:29 PM
insane96
Jun 7, 2013 04:00 PM
forddude2134
Dec 2, 2009 07:45 PM
stangbanger
Nov 25, 2008 12:37 AM
1yamman350
1983 - 2012 Ranger & B-Series
13
Aug 8, 2003 01:55 PM
