429?
Old Oct 14, 2010 | 10:37 PM
Thesteeleboy's Avatar
Thesteeleboy
429?
I just purchased a 1978 Ford F150 4x4 shortbed. The previous owner said it has a 429 in it. The heads have C8VE-E on them. Can anyone tell me what I have. Thanks
Old Oct 15, 2010 | 12:06 AM
cathode's Avatar
cathode
The c8ve heads are the early heads which are easy to make good power with. To accurately determine whether it's a 429 or 460 you need to measure the stroke. In either case it's a good platform.
Old Oct 15, 2010 | 12:54 AM
shorty2tall's Avatar
shorty2tall
ok but is there any way to really tell? i have a 77 f150 and im thinking about either building my 351M or doing the 400M or doing a big block like a 460 or 429. but if i do the 460 id like to do the zf 5 speed with it or an auto
Old Oct 15, 2010 | 01:12 AM
cathode's Avatar
cathode
If the heads are C8VE castings, you have either a 429 or a 460. The only difference (basically) is the stroke length. The block is the same in either case. The only accurate way to tell between 429 or 460 would be to pull a head off and measure the full stroke of the piston. The 460 will have a 3.85 inch stroke and the 429 will have a 3.59.
Old Oct 15, 2010 | 09:12 AM
Thesteeleboy
I measured the stroke through a spark plug hole using a piece of wire and came up with 3.60 so im pritty sure I have the 429. What version of the 429 would this be.
Old Oct 16, 2010 | 11:09 AM
bloodspoint's Avatar
bloodspoint
'68 was the first year for the 429. They started out as Thunderbird engines that year. Nice power, tons of torque, but beware, they're high compression engines. I had one in my previous '79, not my choice, previous owner did it. As I said, lots of power, but it was kind of a hassle to find parts for it. I didn't want to go to headers, because I wanted as close to a stock quiet exhaust as I could get, but there was only one exhaust manifold that would clear on the passenger side, and it was from some 70's full size, and was hard to find, and that engine went through a couple sets of manifolds in 20 years.
Mine also did not like cheap gas. I had to use premium in it, and it still knocked.
I'm much happier for my purposes with a "normal" engine. Easy and chape to get parts, and it runs on regular.
Old Oct 16, 2010 | 12:28 PM
Blown 331's Avatar
Blown 331
I see your point on the compression if thats not your thing. But parts should be cheap and easy to find, can you elaborate on that?
Old Oct 16, 2010 | 12:55 PM
steponit's Avatar
steponit
Installing a 460 -- The Right Way!
Old Oct 16, 2010 | 03:25 PM
jfive's Avatar
jfive
Stick with the 351m and stick a 400 crank in it, with better pistons. 400 is a true truck motor. The hassel of putting a big block in and the money it would cost, is more than it would cost to build a real 400 for a truck. There are lots of parts for them now too.
Old Oct 16, 2010 | 04:36 PM
Thesteeleboy
429
I curently have a 400 in my 77 F150 4x4 that I built. I put a 255 INT/ 263 EXH Comp cam in it, shaved the block to encrease compression {I couldnt find high compression pistons} Edlebrock manifold, and its just not enough power.
Old Oct 17, 2010 | 06:31 PM
Blown 331's Avatar
Blown 331
Whats the reasoning behind this? The 400 was used for 6 years in cars before it made it to a truck.
Old Oct 17, 2010 | 07:05 PM
bloodspoint
Well, certainly I had trouble finding those exhaust manifolds. Also, any time it needed anything, I'd go into an auto parts store, and they want to look everything up by vehicle. Obviously I couldn't say "79 Ford truck". It didn't really come up often, but when it did it was a pain. Mostly it was the exhaust manifolds that caused me trouble, I guess.
That and the gas. It was really expensive to run on premium at about 8 mpg.
I don't need all that horsepower, either. Whatever my current truck has is fine by me. As long as it can haul what I need it to haul, I'm happy.
Old Oct 17, 2010 | 07:09 PM
Blown 331's Avatar
Blown 331
Ah, the manifolds. That makes sense. I didn't think of that, I run headers.
Old Oct 17, 2010 | 07:45 PM
jfive's Avatar
jfive
The reason is the amount of torque it produces, and the rpm at which it produces it. The 400 is a better truck motor than a 429. There isn't enough cubes between the two to justify using the bigger 429. A stock detuned 400 produce more torque than a 429 does. Now here are the stock stats for a 429 208hp@ 4400 326tq@ 2800. Now a 400 with its detuning made 169hp, but more tq than a 429. Now just uping the compression to 9.0 or better, and installing a holley 500 and headers will produce 265hp and 419lbs of tq. A pretty good start for a truck motor if you ask me, and with a 4 barrel intake and 600 carb, it goes to over 300 hp and 429lbs of tq. So with a few aftermarket parts, a 400 ford can make plenty of power, and it was in the design that it may be used to move 2 ton trucks and all their weight. It was in the design of this motor, that ford wanted to phase out the FE motor in trucks, while they just flat out replaced the car motors with the 400 early. Sure you allready knewn this though. LOL
Old Oct 17, 2010 | 08:54 PM
Ken(Ark)'s Avatar
Ken(Ark)
The 460 is the same as a 429 with only the crank and pistons being different . Manifolds or other parts from a '74 through '79 460 would be what to ask for .
