What is this part?
Old Oct 14, 2010 | 11:32 AM
teardropty's Avatar
teardropty
What is this part?
Sorry, I am on a slow internet connection and on a time crunch so I apologize if this question has been answered before. -
I have a 1999 F350 PSD 7.3. There is a part located on the lefthand (drivers side) side of the engine located directly underneath the exhaust manifold and powersteering pump area. It currently is leaking a massive amount of oil. What is this part? It appears to be attached to the engine block. Is this an oil pump? Or ??? It appears to be leaking from a seal. Please help. Thanks.
Old Oct 14, 2010 | 11:37 AM
derek0525's Avatar
derek0525
Oil cooler bob at dieselorings sells the rebuild kit for it I think
Old Oct 14, 2010 | 11:39 AM
derek0525's Avatar
derek0525
Antifreeze and oil go through it just something to look for when you take it appart
Old Oct 14, 2010 | 11:41 AM
derek0525's Avatar
derek0525
Replacement O-rings for Ford Diesel Engines
Here is the link to the rebuild kit
Old Oct 14, 2010 | 11:58 AM
teardropty's Avatar
teardropty
Thanks for the info. I will get a kit ordered.
Old Oct 14, 2010 | 12:01 PM
teardropty's Avatar
teardropty
Does it hurt to run the truck (obviously if it runs out of oil thats a problem) a little bit to move it? Can the antifreeze and oil intermix?
Old Oct 14, 2010 | 12:04 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here read this Thred. https://www.ford-trucks.com/forums/9...ine+oil+cooler
Old Oct 14, 2010 | 12:40 PM
DieselOrings's Avatar
DieselOrings
SPONSOR
You have the outer o-rings going so it will loose oil and coat the engine and oil cooler. If the interior o-rings go, then you will have a mess where the oil and coolant will mix and it is almost an impossible task to get the gunk out of the engine at that time. Do the repair now before you have a big $ repair bill.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old Oct 14, 2010 | 09:24 PM
teardropty's Avatar
teardropty
Thanks for the info. Thats why I love this forum! Also, Guzzle, not big plans to take it on a trip, just wanted to know if it was ok to start and drive it into the shop. Will definately get a kit ordered and fixed right away. Thanks everyone!
Old Oct 14, 2010 | 11:07 PM
mongo75's Avatar
mongo75
Yeah try not to run it more than you have to, 'cause once you start getting coolant in the oil it makes a friggin sloppy mess and coolant is real bad for bearings!
