Master-Cylinder
Old Oct 14, 2010 | 07:14 AM
precisionplumbing55's Avatar
precisionplumbing55
Master-Cylinder
I want to install a master-cylinder with 2 wells, What should I use in a 66 F100 Thanks Steve
Old Oct 14, 2010 | 09:53 AM
jowilker's Avatar
jowilker
May I ask why after working for 44 years with a single bowl you think it now needs 2?
If you want to upgrade your brakes, swap in power disc from a 73-79, grab the power steering at the same time. Do it right and you might get away with a $100.00 or less.
John
Old Oct 14, 2010 | 10:54 AM
daveengelson's Avatar
daveengelson
Here's a thread on simular topic may find helpful.
https://www.ford-trucks.com/forums/7...ing-valve.html
Should be able to find MC at local Napa auto parts including which side of the MC the brake lines are connected.
Old Oct 20, 2010 | 02:49 PM
DPhillips's Avatar
DPhillips
I used a master cylinder from a 68 Mustang. Bought it at NAPA. It works very well.
Old Oct 20, 2010 | 04:08 PM
Mike G's Avatar
Mike G
I used a drum/drum M/C from a 69 F100 and cut about 1" off the actuator rod, plugged a line on the distribution block and added a connector to the new second line. Installed an electric brake light switch on the brake pedal arm to work the lights. There have been various write-ups on here about doing this, some searching will produce plenty of info.
--Mike
Old Oct 20, 2010 | 05:43 PM
precisionplumbing55
Thanks everyone, you've been a big help!
Old Oct 20, 2010 | 05:45 PM
thechief66's Avatar
thechief66
John
If you'd ever had your brakes go out driving down a mountain pass hauling a heavy load, you wouldn't ask that question!
Yep it happened to me!
After that I got a master cyl/booster off a 68/72 era F100 & put it on my 66. That was a long time ago, so I don't recall all the details, but IIRC it was a pretty straightforward swap.
Old Oct 20, 2010 | 06:56 PM
jowilker's Avatar
jowilker
Never been down a mountain pass in a truck not up for the job, but my truck was upgraded to power discs which would be a much better choice.
John
Old Oct 21, 2010 | 12:01 PM
thechief66's Avatar
thechief66
If your truck's got discs, I'm sure it's got a dual master cylinder, too. It's a good safety upgrade for any vintage vehicle to have redundant braking.
As for not being up for the job, I had 7,500 lbs of scrap metal in the bed of an F100, going down a 7% grade...ah, to be young & foolish again...
Old Nov 4, 2010 | 06:33 PM
phjbbu's Avatar
phjbbu
upgrading to two-bowl
John
In my years of driving vehicles with two bowls, and after experiencing brake line failure in some of those vehicles, I honestly wondered what the big advantage was of two versus single. Yes, I know the theoretical advantages, but have yet to experience them in real life. I cannot think of a better way to say it than jowilder has. Gave me a chuckle, John...not at anyone's expense, tho...thanks.
Paul's 64 F250 and 66 F600
Hobdy
36
Apr 22, 2019 04:44 PM
F-250 WARHORSE
Dec 19, 2016 02:16 PM
RUBICON
2009 - 2014 F150
Jun 29, 2015 02:30 PM
jeeperman2001
May 8, 2015 06:45 AM
xc4life_nemo
Nov 9, 2006 06:38 AM
