Sponsored by: Real Truck
back spacing
Old Oct 13, 2010 | 09:09 AM
pfl8888's Avatar
pfl8888
back spacing
I am lifting my 2004 f350 super duty with an 8 inch lift and 38x13 with 16x10 wheels. Any suggestions on backspacing and will these tires rub?
Old Oct 13, 2010 | 09:30 AM
cartmanea's Avatar
cartmanea
A backspacing changes with width, so look at the offset instead. A -25mm offset will probably rub a little bit on the springs, so more negative than -25mm would be good, but can be hard to find. A few make -50 or -51mm wheels, Ion makes a -41mm and you can get some XD wheels in a -44mm.
Old Oct 13, 2010 | 07:47 PM
pfl8888's Avatar
pfl8888
I am looking at getting the mickey thompson classic II wheels.....any idea if they will work? Or could I put on wheel spacers?
Old Oct 13, 2010 | 09:37 PM
cartmanea's Avatar
cartmanea
Those are -27, so it will probably rub a little. You could limit your steering so it doesn't rub, but I wouldn't want to lose any steering.
Old Oct 14, 2010 | 08:20 PM
pfl8888's Avatar
pfl8888
how about the mickey thompson classic II that are 16x12, they have an offset of -51? or could I go with a smaller offset and use wheel spacers?
Old Oct 14, 2010 | 08:56 PM
cartmanea's Avatar
cartmanea
I wouldn't use wheel spacers and 12" wheel is pretty wide for a 13" tire.
