brake line
Old Oct 12, 2010 | 06:14 PM
Roy C's Avatar
Roy C
brake line
I have an '87 F150 4x4. There is one brake line that goes to the rear brakes and then at the rear axle it goes into a tee. This tee feeds each side wheel. Also out of the tee there is a rubber hose that has some type of small device on it and it's mounted just below the bottom of the bed. The little device looks like some kind of breather but that doesn't make any sense. Does anyone have any idea what it might be?
I'm trying to bleed the brakes and I have a leaking line on the left side.
Old Oct 12, 2010 | 06:25 PM
danr1's Avatar
danr1
Yea its a breather for the axle housing, has nothing to do with the brake lines.......well other then hold that Tee in place.
Old Oct 12, 2010 | 07:26 PM
Roy C's Avatar
Roy C
danr1 --- thanks for the info.
Old Oct 12, 2010 | 08:00 PM
danr1's Avatar
danr1
You'll likely find the line is 3/16" and has two different size fittings on each end, you'll need a appropriate length of ready made brake line and an adapter shown below to use it. A ready made line will have the same size fitting on both ends, one end to small.
<a href="http://photobucket.com" target="_blank"><img src="http://i28.photobucket.com/albums/c250/danr1/lineadapter007.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i28.photobucket.com/albums/c250/danr1/lineadapter003.jpg" border="0" alt="Photobucket"></a>
Just in case you where not already aware.
Old Oct 13, 2010 | 05:42 AM
Roy C's Avatar
Roy C
Thanks for the pics. I haven't even gotten to the brake line yet as I'm still trying to get the bleed screws working. This whole truck has been metric EXCEPT the bleed screws. A 9mm wrench is to small and a 10mm wrench is to big but a 3/8" wrench fits perfectly. I had to replace both bleed screws but now I'm thinking they are incorrect. I replaced exactly what came out but I don't think it's right.
Old Oct 13, 2010 | 05:44 AM
Roy C's Avatar
Roy C
Make that a 5/16" wrench.
Island Time
Aug 24, 2014 12:44 PM
CharlieBravo
1997 - 2003 F150
Jun 7, 2009 05:36 PM
bigsuperduty
Oct 31, 2006 07:28 PM
jalawn
Apr 22, 2004 06:42 AM
