Sponsored by: Real Truck
tpms interchange
Old Oct 11, 2010 | 09:45 PM
ItsAllJustCastIron's Avatar
ItsAllJustCastIron
tpms interchange
I have a chance to buy a compete set of alloy rims and tire take offs from a 2011 f350 to put on my 08 f350. Will the newer tire pressure sensors work on my 08?
Thanks
Old Oct 12, 2010 | 08:17 PM
ItsAllJustCastIron
musta posted on the mopar board,nobody knows anything?
Old Oct 12, 2010 | 09:14 PM
scububbs's Avatar
scububbs
I'm not sure, in my owners manual for my 2011 there is a procedure for "training" the TPMS monitors, one wheel at a time. If you have your manual you might see if that procedure also works on the 2008 trucks. If it does there would be a good chance that the new tires and wheels would work. I haven't read or seen anything that is different on the TPMS from my '07 to the 2011.
Old Oct 13, 2010 | 05:33 AM
2011SD's Avatar
2011SD
I put 09 rims on my 2011 and the sensors worked the tire shop just pulled them out of my 11 rims and put them in the 09 rims.But it may not work the other way around because the older trucks had the band sensors and the new ones just sit in behind the valve stem.Are the rims your buying going to come with the sensors in them?
Old Oct 13, 2010 | 10:16 PM
ItsAllJustCastIron
yes, 2011 complete take off wheels and tires.
Old Oct 19, 2010 | 10:56 PM
ItsAllJustCastIron
bumping up
AADAD1998
Jan 22, 2017 11:13 PM
Sleepyguy
Sep 29, 2016 11:14 PM
mattymax
Apr 9, 2015 07:48 AM
andrew.finlay
Mar 19, 2015 04:51 PM
Jet Blast
Nov 30, 2007 05:41 PM
