1965 REAR AXLE CODE 23 ?
Old Oct 11, 2010 | 12:09 PM
3360stepp's Avatar
3360stepp
I need some assistance. I finally picked up my 1965 F350 dump on Saturday. The warranty plate list the rear axle code as a "23". I can only locate a decoder for a 1967 which indicates on that year truck the axle would have been a Dana 70 with a 5.13 ratio. Are there any numbers on the axle housing to verify the ratio. I also have a 1966 F350 with a Napco conversion package that I would like to swap to the 1965. The 1966 doesn't have a warranty plate, so I'm at a lost as to what rear axle it has. So I'm hoping it has some casting numbers that will determine what rear axle it has. I was hoping to avoid swapping out the rear axles. Thanks John
Old Oct 11, 2010 | 06:03 PM
Customcab's Avatar
Customcab
Is there still a axle code tag on the either the front or rear of the axle; should be on drivers side bolted on one of the center housing / plate bolts. If not (What are the bolt head size on the center housing). And is it with a plate cover or the center section seems to un-bolt towards the front?
Old Oct 19, 2010 | 01:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
23 = 1961/72 F350 Spicer-Dana 70 / 5.13-1 / non Limited Slip / 7400 lb. Rear Axle Capacity.
Old Oct 19, 2010 | 02:24 PM
3360stepp's Avatar
3360stepp
Thanks
Thanks Numberdummy for the assistance. That what I thought was under my truck. As I said in my first post, I have another F-350 it's a 66 model that doesn't have it's warranty plate. I have located a casting number on the back side of the rear axle that I believe reads 030788. Does this mean anything? I still trying to determine if both axles are the same.
Thanks,
John
Old Oct 19, 2010 | 02:34 PM
NumberDummy
Thanks,
John
The Ford rear axle tag on Dana axles of this vintage is (was) under two of the bolts (located on the passenger side) that retains the inspection cover to the housing.
Do not be surprised if the tag is missing. Thoughtless people removed it, forget to replace it when they re-installed the inspection cover.
There are no codes or numbers stamped/marked on the housing inre to the ratio.
Without the Warranty Plate, without the tag, there is no way to determine what the ratio is, unless you turn the driveshaft, counting its revolutions inre to one complete turn of the right rear wheel.
1966 F350 Dana 70 available axle ratios: 3.73-1 / 4.10-1 / 4.56-1 / 4.83-1 / 4.88-1 / 5.13-1 / 5.87-1
Old May 12, 2015 | 08:46 PM
bigchruck's Avatar
bigchruck
hey numberdummy, me again, So according to this thread if my door tag says axle 23, my 64 350 duelly is a Dana70?
Old May 12, 2015 | 09:39 PM
NumberDummy
Originally Posted by bigchruck
hey numberdummy, me again, So according to this thread if my door tag says axle 23, my 64 350 dually is a Dana70?
23 = Spicer(Dana) 70 Rear Axle / 5.13-1 / 7,400 lbs. Rear Axle Capacity.
Some 1961/62 F350's have 70's, some have Timken B140's. All 1963/79 F350's have 70's except 1979 F350 4WD's that have Dana 60's front & rear.
Old Mar 10, 2016 | 06:12 PM
stagecall's Avatar
stagecall
I have the same code on my 66 f350.I plan to go to 3.00:1.Mostly drive on the freeway.
Old Mar 10, 2016 | 08:42 PM
stagecall's Avatar
stagecall
axle code
Thanks for the info.I have 89 f150 w/4.9 4 speed.Thats going in my 66 F350.Let you know how it goes
Old Mar 10, 2016 | 09:54 PM
NumberDummy
Originally Posted by stagecall
I have the same code on my 66 f350. I plan to go to 3.00:1.
AFAIK, there is no 3.00-1 ratio available for a Dana 70.
flowney
Dec 28, 2017 03:54 PM
teamtestbot
Sep 25, 2017 10:45 PM
tiger100
Nov 15, 2016 10:59 PM
Obscure69
Oct 21, 2016 12:30 PM
cmo
Large Truck
Aug 20, 2016 11:26 PM
