Sponsored by: Real Truck
Electric Fans
Old Oct 16, 2010 | 08:42 PM
Kajtek1's Avatar
Kajtek1
Math is one story, but the truth is that electric motors have very high efficiency, so you should start with about 98%. Still the belt running alternator would cut it pretty drastically.
Read my previous post again. In diesel sedan engine fan is not necessary. Sure I didn't go this season to 125F desert, but I drove my car fast in 100's.
Old Oct 16, 2010 | 09:09 PM
ruschejj's Avatar
ruschejj
Well, how about using the EGR cooler design cue. Make a heat exchanger where hot engine coolant passes thru a manifold that is chilled by the A/C system. Get rid of the radiator all together and just have a chiller.
You still need to rob engine HP but maybe the heat exchanger could be engineered to be more efficient than the traditional radiator/fan.
Old Oct 16, 2010 | 09:22 PM
dchamberlain's Avatar
dchamberlain
Has it ever occurred to anyone that if Ford could have figured out how to get the necessary cooling with an electric fan and gained even just a 1 MPG gain that they would have?
Especially considering the fairly complex vistronic fan clutch and sensor that they used instead.
If they could have done it, they would have saved money per truck, which adds up, and they would have been able to claim higher MPG to the EPA and on the sticker and in ads, etc.
If they could have done it, they would have.
Old Oct 16, 2010 | 10:07 PM
Kajtek1's Avatar
Kajtek1
You are giving too much credit to Ford. My son drives 1987 Mercedes diesel sedan. Per comparison to my 99 Ford, the sedan is well advanced vehicle.
It only lacks cupholders.
Old Oct 18, 2010 | 06:37 PM
mwsF250's Avatar
mwsF250
Never, ever, underestimate the power the bean counters have! Especially in large American corporations!
Pinto. Need I say more?
Speaking as an engineer, I can say the hardest thing in the world is getting the best design to market.... EVERY other member on the "committee" has their own goal and (secret) agenda and NEED to force compromises to the design just to make their point. Harumph.
Old Oct 18, 2010 | 06:52 PM
mwsF250's Avatar
mwsF250
98%? If you have some of those, I want them!
50 to 85% is typical for the DC motors I can afford.
For the record, 50 to 65% is typical for consumer alternators.
Old Oct 18, 2010 | 06:55 PM
dchamberlain
Right... And if the engineers went to the bean counters and said they could get a MPG gain with a simpler (less expensive) design, I'm sure the bean counters wouldn't want to have anything to do with it.
Old Oct 18, 2010 | 10:26 PM
Kajtek1's Avatar
Kajtek1
98 % efficiency seems to be laboratory results, but 90% becomes pretty standard.
Electric locomotives benefit from the high efficiency of electric motors, often above 90%. Additional efficiency can be gained from regenerative braking
Electric locomotive - Wikipedia, the free encyclopedia
Old Oct 19, 2010 | 05:46 AM
Furian's Avatar
Furian
You Keep What You Kill
Here is an interesting read...
The Myth Of The Electric Fan
Old Oct 19, 2010 | 11:06 AM
Johnny Langton's Avatar
Johnny Langton
He's an idiot. I've seen that before, and it's wrong.
JL
Old Oct 19, 2010 | 11:22 AM
Furian's Avatar
Furian
JL
LOL! I knew that someone would say that about the article...
Old Oct 19, 2010 | 11:44 AM
mwsF250's Avatar
mwsF250
Ahh, those motors. Unfortunately, those are an extreme, and quite expensive. The ones used in typical consumer applications are in the 50 to 85% range. I'd GUESS the ones used in aftermarket fans would fall around 60% at best...
Similar to alternator/generators. The massive ones (with permanent magnets) used in power plants can reach 98%, but the ones small and affordable enough for cars are down iaround 50 to 65%.
Generously assuming 60% and 60% efficiency, the mechanical to electrical conversion is 36% at best.
Spkrvr
Sep 5, 2014 08:38 AM
helpfulguy
30
Dec 6, 2012 03:04 PM
Club Wagon
1997 - 2003 F150
Oct 29, 2007 08:39 AM
hotrodfeguy
1983 - 2012 Ranger & B-Series
Feb 26, 2007 08:02 AM
