Ranger Represents Rear-Drive Trucks Everywhere
Ranger is lifted on 37-inch wheels and it handles serious mud without four-wheel-drive.
Most Ford Ranger owners who plan to go off-roading will make sure to buy a truck with four-wheel-drive, but this week’s Muddy Monday video shows that having a 4×4 isn’t a requirement. This video from the Toje Labs YouTube channel shows that with a good set of tires and careful line selection, a rear-drive Ranger can play in a serious mud pit just as well as the bigger, four-wheel-drive pickups. Even when it gets stuck in the middle of the watery pit, the driver is able to make some moves to get himself back to dry land.
Third Generation Ranger
The details on this Ford Ranger are limited to the fact that it is riding on 37-inch tires. As you can see, the tires are considerably taller and wider than any stock tire, wrapped around Cragar wheels that extend out well past the body. We are guessing that this truck has been lifted a bit to help these tires clear the body and to provide some extra ground clearance, but we don’t know for sure.
Based on the grille and overall body style, we believe that this model was from the 1998 through 2005 era of the third generation. As for the powerplant, it sounds like a V6 with an open exhaust setup and a manual transmission. There were three V6 engines offered during the third generation of the Ranger, all of which were offered with a manual transmission, so we don’t know what is under the hood.
We do, however, know that the front tires aren’t helping this Ranger dig through the mud. This compact Ford either doesn’t have four-wheel-drive, it has four-wheel-drive and it is broken, or the driver simply isn’t using it. In any case, while the rear tires sling mud everywhere, the fronts just creep along at the speed of the vehicle.
Attacking the Slop
The video begins with the Ford Ranger driving along the edge of what appears to be a small pond. The bank of the pond is muddy and deep, with similar footing in the water as well. This looks like the kind of situation in which you wouldn’t want to drive a rear-drive pickup, but the Ranger easily makes its way along the far bank, turning across the back and then cutting through the deep middle. At no point does the compact Ford struggle, even with only the rear wheels spinning.
After the first successful lap, the Ranger driver powers back into the pit in reverse, then heads out for another lap. The path starts off the same, but when the driver gets to the far edge, the truck shoots off into the deeper grass. After a few seconds, the Ranger heads back into the water. The driver then tries to make a left, but when he meets resistance, he backs up and on the end of the path that was completed earlier.
Crank up your speakers and enjoy!
