Hydra Tunes
i had received jelibuilt tunes a few years ago, but also been chasing a problem. Think it’s tune related. Long story short when the TC locks my truck loses and Boggs down. Have essentially put a lot of new parts and still does it. It’s Been at a shop for like a month now, thinking it’s a tune problem. Other than that there are zero problems or codes.
New KC300x stage 2 turbo (63/73)
Full force 205/30 injectors
Stage 2 AUS-TEX Trans
CNC Fab Stage 1 HPOP
24x14;8x170 on 37.5” Tires 240k psi Head Studs
FASS Titanium 220GPH
Mishimoto trans cooler
new idm and pcm
So did the tuned you have work at one time and were written for the upgrades you've listed, the major ones at least? If the tunes did work at one time and no major changes have been made I'm not sure how a tune would go "bad". It's just data, nothing to go bad. No moving parts and indefinite shelf life.. The chip can fail but not sure it could in such a way as to cause such a specific issue. Have you tried dumping the files on the chip and reloading the originals?
why I’m on here to see if someone that knows can get me tunes for my truck.
I had paid for custom and couldn’t tell you the difference. But to me they seem like generic tunes. “ 01 - Local File: TNAA42_30N_ MODIFIEDSTOCK-EMISSIONS.hcf
02 - Local File:TNAA4S2_30N_STRENUOUSTOW.hcf
03-LocalFile:TNAA4S2_30N_TOWPERFORMANCE.hcf
04 - Local File : TNAA4S2_30N _DAILYDRIVER.hcf
05 - Local File : TNAA4S2_30N_HOTSTREET.hcf
06 - Local File : TNAA4S2_30N_DRAGRIPPER.hcf
07 - Local File: NAA4S2_30N_H-IDLE-1100RPM.hcf “
Those 2 pcm numbers should use the same tunes so I don't believe that's your issue. Judging by the tune files they seem like correct tunes for the 30n which would be 30% nozzles which you have. I would try to reload the tunes onto the hydra an make sure pcm is cleaner well where the hydra connects.
the pcm pins are clean, made sure of it. How would I reload tunes, when they were put on by the shop I bought the hydra from. I don’t have the files. The most major upgrade I recently did was the transmission. I’m not a diesel expert but maybe TC stall speed?
If there jelibuilt tunes I would contact them and ask for there opinion and see what they say. The tunes they write control tranmission parameters as well.
the files are Downloaded from PHP,
you MUST have the Windows Laptop connected to the Internet when you are installing Hydra tunes,
you do NOT need any shop's help to do it, you do it yourself.
just follow the instructions in the pamphlet, or download them, or watch Video a couple times.
got a problem,
call PHP and talk with them, they talked with me for an Hour and never got upset with me....
got a problem,
