Metallic Gray Bronco Gallops Through the Windsor Plains
With the strength of a 351 Windsor V8 behind it, this ’69 Bronco underwent a full frame-0ff refurb during the last two years.
It’s been a long wait for a new Bronco. Soon, though, the new retromod “Mustang of the Dirt” will gallop back on the road and trail, looking much like it did in the spring of 1965. And with a wide assortment of accessories from the factory, plus plenty more to come from the aftermarket, the new stallion will be as unique as its rider.
Of course, there are fans who’d rather have a first-gen Bronco than the New ’20s version of the first-gen Bronco. For them, we happened upon this Metallic Gray mare on Bring a Trailer ready to go home to a new stable.
The current owner of this Bronco bought it back in 2009. They then refurb’d the horse over 2019 and 2020, nose to tail. The result is a burly off-road rig with plenty of comfort for the trek to the trail and back.
Did you notice the big bump on the hood? It’s there to make room for the Bronco’s 351 Windsor V8 under it. The big mill was already in play from a previous owner, though output is a mystery. It’s likely enough to climb over every mountain, though. And with fresh oil and filters, the motor will push the horse across the plains of Windsor for a long time to come.
Inside, the Bronco features rubber floor mats protecting the new-ish floorboards from errant boots. Meanwhile, an aluminum dash houses all of the information the driver needs, without any infotainment to distract them from the rough terrain ahead. A newer radio with CD is as modern as it gets inside, while diamond-plate doors and pedals boost the utilitarian vibe up to 11.
The Bronco rides high upon a three-inch lift to its body, and another 3.5 inches through the suspension. A Dana 44 up front and a Ford 9-inch out back support the 15-inch wheels and 35-inch all-terrains, while a three-speed manual with two-speed transfer move the 351’s stout horse and torque around. Whomever saddles up next will have the time of their lives, to say the least.
UPDATE: This Bronco sold for $45,750 on 11/11/2020.
Photos: Bring a Trailer
