‘FTE’ Member’s F-250 is the Perfect Winter Project
F-250 is in solid exterior shape with minimal rust, but the engine needs to be rebuilt.
Classic Ford trucks have become popular vehicles to restore, as they can often be had for less than a car from the early 1970s. The problem is that most trucks have been driven hard for their entire lives, so they are in terrible physical condition. Fortunately, Ford Trucks Enthusiasts forum member “SanCarlosTruck” posted his 1972 F-250 Sport Custom for sale in the FTE Marketplace. It is in California with very minor surface rust. The only downside is that the engine was run without oil and it needs to be rebuilt.
F-250 Sport Custom Introduction
When the OP first posted his 1972 Ford F-250 Sport Custom for sale, he provided a ton of information on the truck, its history and what it needs to get back on the road. Unfortunately, while it is in pretty solid shape, it is not in proper running order.
1972 Ford F-250 Sport Custom – Wimbledon White with very little rust on the outside body. The bed of the truck has been protected by a camper shell and has not been exposed to the elements.
This truck requires an engine rebuild since the Oil Pump failed and it was driven with low Oil Pressure. This truck was a project truck from the previous owner and I just haven’t had the time to tackle what is needed to get it back into top shape. The body of the truck has very little rust on it and the bed is rust free.
The truck has a new automatic transmission and new rims and Cooper HT3 tires with very little mileage on them. The engine has a rebuilt 2 barrel Carburetor, aftermarket EdlebrockAir Cleaner (The Original Metal Pan one is included but has a fair amount of rust on the underside). New Water Pump, New Timing Chain, New Alternator, New Upper and Lower Radiator Hoses. I have replaced all the rubber window seals on the Driver Side and have the kit for the passenger side but haven’t had a chance to change them out.
The interior of the truck has an aftermarket bench seat, but we found an original bench seat from another 1972 Ford Truck that needs reupholstering, but is included in the back of the truck. Also included are the original rims along with some sketchy tires on them. This truck also was once equipped with an AC system but at the time we got the truck it wasn’t working so I removed it and the bracket and compressor are included.
The truck originally had dual gas tanks, but the tank behind the bench seat isn’t working. The truck is equipped with an aftermarket towing package and is set up for a second auxiliary battery (also included in the back). The Master Brake cylinder needs replacement and I have purchased a replacement Master Brake Cylinder but have not installed it.
This truck will need to be towed as it is not in running condition, I am listing this truck for 3500 dollars but as it isn’t in running condition I am willing to listen to any offers. This truck has a lot of potential due to the condition of the body, or could be parted out for a good deal more than 3500. Thanks for checking out my listing.
The seller also included 20 pictures of this 1972 F-250 inside, outside, under the hood and under the cap. As you can see, this truck is showing its age, but there is only a little surface rust. A touch of bodywork in a fresh coat of paint and this F-250 is ready for the Cars and Coffee.
Time for an Engine Swap
Oddly, while the 1972 Ford F-250 owner provided loads of information in this for-sale listing, he doesn’t mention which V8 engine is under the hood. There were three different V8 engines offered in 1972, measuring 302, 360 and 390 cubic inches. We don’t know for sure, but this appears to be the 390-cubic inch big block. If it is indeed a factory big block truck, the buyer may want to rebuild the stock engine, but an engine swap would make this truck a whole lot more fun to drive.
This F-250 is listed for just $3,500, so there is plenty of room in the budget for a newer engine swap. A crate engine or a takeout from a newer truck would introduced gobs more power, but more importantly, a newer fuel injected engine would make for an easier daily driver.
If you have a Ford V8 laying around, this F-250 would be the perfect home for that engine. Drop in your engine and add a coat of paint and this classic Ford truck will be ready to cruise.
You must be logged in to post a comment.
