F550 First Trip, Heavy tow, Noises / shudder
I am not a hotshot guy but took a 600 mile trip today (light hills) starting with 500 miles on the truck and ending with the odometer around 1100 miles.
Truck, bed, trailer scaled at 22,500. Had about 22,000 on the deck for a total of 44,500.
The last diesel I owned was a 6.0 with multiple 7.3 prior so I have not had a PSD for a lot of years.
I noticed the below issues and wanted to see if they are normal or if others have experienced this.
1. there is a tick in the exhaust under the passenger rear door. It sounds like a lifter tick, but seems to be coming from some part of the exhaust.
2. acceleration from a stop a pretty good shimmy on the 1-2 and 2-3 upshifts. Not crisp and clean but a lot of shaking for a few seconds. Trans temps were in the 220 plus.
3, turbo started sounding different around 1100 miles. Heard it spooling, but also heard what sounded like a hissing from a different location than the spooling when the dash showed around 20 psi of boost on up to 30 or so. Maybe a boost leak? My mind goes back to the plastic 6.0 boost pipes and the broken down Y pipes but a different sound for sure.
lastly the exhaust brake was on for the trip and not in auto.
Not trying to pick the thing apart, but want to know if this is normal or needs to get looked at.
Number one is pretty common, the tick is considered normal. What you're most likely hearing is the def injector cycle. Went up against the building. Say going through a drive-thru you will hear it really loud.
Number two can be considered somewhat normal also. I believe what you are experiencing is Axel wrap. I will experience this occasionally when my pin weight over 7,500 lb.
You're trying to get a whole lot of mass moving at once. There is solutions like traction bars out on the market to help resolve that issue.
As far as number three, the turbo and engine will sound different at times depending on the EGR cycle. If you experience a power loss at that weight, you'll notice it very quickly.
Never hurts. Double check all the boots, especially the clamps.
Think you nailed the Def injector
and yeah maybe the sound was the EGR. I could see this making total sense.
thank you!
The EB seems to get better after about 5-6k miles, or maybe it was me learning to keep the R's up when towing in the mtns...
My Ram would go dead, no power at all, every once in a while because it couldnt make up its mind to upshift or downshift. "Dead pedal"
will try the pedal in one position. The times it did it was on a slight incline and rolled into the throttle about half way but did not really want to go so had to go about 3/4 to get some momentum.
But axle wrap, when your rear spring pack is a foot thick? Not likely. Id have to drive it.
Trying to get 55,000 lb moving......
My 24, had the load deflection package, basically the 2-in block. Once I remove that and lowered the truck, it was much happier.
Op, do you know if you have the load deflection package? Basically it's a 2-in block, with a shim between the leaf pack and the axle.
will look when I am back with the truck tomorrow.
Also recommend to do an oil change now.. Leave the filter though.
Driving Hints - Breaking-In
Breaking-In
Your vehicle requires a break-in period. For the first 1,000 mi (1,600 km), avoid driving at high speeds, heavy braking, aggressive shifting or using your vehicle to tow. During this time, your vehicle may exhibit some unusual driving characteristics.
Breaking-In
After having hundreds of brand new vehicles over the last 30 years in the fleet, while years ago that used to have some factual merit to it, nobody does that anymore. That picture I showed earlier, it was a 2017 f550, the day I picked it up I drove across town and picked up two gooseneck double stacked trailers and drove to the east coast from Texas. At truck had 450,000miles on it before I even retired it
If it wasn't leaking so much oil, I would have kept it
My buddy has it, deleted it and is still rolling around in it.
My rollback, the bed weighs 9,000 lb, You think the Ford dealer broke it in before they put the bed on, not.
Next somebody's going to tell me to lock my front differential in for a thousand miles so I can break it in
https://www.youtube.com/watch?v=fwzLY62_uIE&t=83s
The weight I run, at 50,000 lb, for a vast majority of the truck life, the wear and tear is probably triple what the average truck will see.
You have no idea of the intense heat load that is put on an engine now when it is stressed for hours on end, the heat cool cycles takes a toll on the engine. Tolerances open up, seals dry up, etc.
Original motor, transmission, rear end, DPF 100% original. That is unheard of unless you're doing religious proper maintenance.
Hell I only had two sets of brakes ever put on the truck, in oil is religiously changed it's 7,500. My entire Fleet is that way. We used to do $200,000 MI, then get rid of the truck because of body, usually runs. Obviously it was a 2017 and it didn't rust, the bed did.
Besides some oil leaks, by larger concern was the shape of the bed and hauling a gooseneck that weighs 40,000 lb. It was deteriorating to the point where I didn't feel it was safe, it's still past DOT Inspection, but I wasn't dumping $10,000 to replace the bed on a truck with that many miles.
Go back to googling.
Look at AT&T, Verizon, your gas company, your water company, etc. you think these vehicles get driven around unloaded for a thousand miles before service bed is put on, before the cranes are put on, before anything is done,
No.
