New air filter on my truck
Old 08-31-2004, 09:02 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
I just installed a NAPA air filter part # 6637 on my '99 PSD. It required that I remove the stock filter housing to get it to fit. BIG filter. The rubber air boot that went to the stock filter housing fit right over the flange on the new air filter. It was a bit of a stretch getting it on, but in the end it was a perfect fit.
Old 08-31-2004, 09:47 AM
johnsdiesel's Avatar
johnsdiesel
johnsdiesel is offline
I bet you can hear your turbo a lot more now, I know I did.
Old 08-31-2004, 09:56 AM
mtncrawler's Avatar
mtncrawler
mtncrawler is offline
Somewhere on this site I found the part numbers for replacing the Donaldson # B058011 that came with my Tymar setup. Napa # FIL6637, Baldwin # PA2818, Carquest # 88637. Sounds like you put together a similar setup.
Old 08-31-2004, 11:00 AM
RickyBR's Avatar
RickyBR
RickyBR is offline
kwikkordead,
Old 08-31-2004, 11:02 AM
RickyBR's Avatar
RickyBR
RickyBR is offline
sorry, got cut off.
Old 08-31-2004, 11:16 AM
RickyBR's Avatar
RickyBR
RickyBR is offline
KWIK, is everything else stock? all you did is took the stock box off and put that big honkin filter on?
sorry about having to do this in three replys, I kept getting bumped off somehow.
Old 08-31-2004, 04:02 PM
johnsdiesel
Try the edit feature. It works wonders.
Old 08-31-2004, 04:24 PM
mtncrawler's Avatar
mtncrawler
KOD may have done just that. Friend of mine with a '99 cummins saw my Tymar, took the filter off and slipped his intake hose over the filter flange and tried it out. Liked it so he bought one and is still running that way. I think the Tymar setup supplys an intake pipe to smooth out the airflow instead of using the factory connections.
Old 08-31-2004, 05:55 PM
cangim's Avatar
cangim
cangim is offline
Kwik, is your PSD a pre '99? I have been thinking about doing the same thing with my next air filter change, mine is a pre '99. If the only thing I would have to do is take the box out and put the new filter in, that would make things a hole lot easier.
Mike
Old 08-31-2004, 06:05 PM
gotdiesel's Avatar
gotdiesel
gotdiesel is offline
yeah if that will work i think i would just do the same thing pull the factory box and clamp up the new filter. that is assuming they make one that will fit the 97. thanks for the ideas
Old 08-31-2004, 07:28 PM
03grizz's Avatar
03grizz
03grizz is offline
I did the same to my truck as kwik but I didn't like the fit so I went to the hardware store and bought a 3" (I think) abs coupler and a big hose clamp and slid it into both the filter and the intake it seemed to be a better fit and only takes up about an extra 1/4" of space. One other thing, don't just drop the filter in to the space where your old one sits make sure that you put it down on an angle like in kwikordeads picture if you don't your hood won't close right
Old 08-31-2004, 08:45 PM
Pocket's Avatar
Pocket
Pocket is offline
What the?!?!?!?!?!?!?!?!
You got yours to fit without an adapter???????
I have the exact same filter from Napa, so I'm stumped.
Old 08-31-2004, 09:27 PM
Kwikkordead
Mine is a 99.5 with the 4" rubber hose. I got it to fit with a bit of a stretch. And a bigger hose clamp, the factory clamp just wouldn't reach anymore. I had to get two hose clamps and open both of them up and join them end to end to make one very large clamp. And trim off the rubber guides that hold the factory clamp in place. I believe the earlier trucks have a smaller hose that must be adapted out to fit that very LARGE filter.
Old 08-31-2004, 09:32 PM
cookie88's Avatar
cookie88
cookie88 is offline
If the filter won't fit in the stock tube (mine didn't either), just get a piece of 4" exhaust tubing (or aluminum, PVC, whatever, so long as it's 4" OD) about 5" long and one more clamp to mate the two together.
Old 08-31-2004, 09:49 PM
Pocket's Avatar
Pocket
Pocket is offline
I was curious so I had to try it, and sure enough, it fit. Also the stock clamp fit as well. Few minutes of cursing to wedge it on, but looking at how tight it fits, it sure won't leak.
BTW, mine is an '02 with a 4" intake hose.
Quick Reply: New air filter on my truck
