A Carburetor GADGET that actually works!
on
It's called the Thompson PowerBlast Plate, made by Thompson performance.
I was turned onto this thing by another reputable Bumpsider here on the forum.
What it is, is a little brass contraption bent up and shaped to fit around the accelerator pump shot nozzles. It intercepts the shot, and fans out the gasoline into a mist rather than a straight liquid squirt. ( kinda like washing a spoon in the kitchen sink)
Here's a video of it.
https://youtu.be/_xTnQ9e-SIM
Obviously, that in itself is going to work better. And really, that's all it needs to do.
The main thing they market it for is improved throttle response. More akin to what Fuel Injection would be.
I can say that the throttle response DID IMPROVE.
Now, for what it is, I think it's way over priced. However, there is obviously some engineering behind it, and it is fairly high quality. Your not paying for the part as much as the labor and time to make it. Being an amateur machinist and fabricator, I was going to try to replicate it, but the time I would spend trying to make the same thing would cost more than buying one.
it's not something that you can't live without. The difference on my setup wasn't like night and day, but it is noticeably better.
Bottom line, if you got a few extra bucks, (40-50) then this thing might be worth checking out. It does exactly what it says it does, and I'm not ever taking mine back off, but I don't know if I'll buy another one either.
It makes sense. Finer droplets of gas will atomize easier and better with the airflow. Like trying to put a Holley 850 on a 260 V8. Lay too big of fuel droplets for way to slow of air speed. Finer droplets of fuel is also why Ford designed in the Annular Discharge Booster venturis in the Autolite 2100,4100, and Ford/Holley 4180.
on
Originally Posted by HIO Silver
I tend to be a skeptic when it comes to gadgetry. I mean, if it works then why is it the carb manufacturer hasn't incorporated it already?
The gadget prolly makes up or masks existing carb issues.
Originally Posted by Tedster9
It might work, but 60 clams for a piece of brass is a bit much I'm thinkin'.
I bet a lot of gearheads are fabricatin' their own. One of the forums, somebody was skeptical, asking just how much fuel is used by the accelerator pump. The answer is, more than you might think, in stop and go driving. It's just got to be a factor for in town/city fuel mileage killer. Everytime ya hit the go pedal.
Disconnect the lever, run a tank through and compare mileage with prior result.
Yeah, the truck will bog but you get the answer.
