Vacuum lines 460 engines
For starters, there's a big one to the power brake booster. If you have automatic transmission, that'll get a small one. There'll be another small one that goes inside the cab for the heater/AC controls. If you have cruise control, one may go there.
Looks like you don't have an EGR plate, so we won't mention that one
You'll have a ported vacuum from high on the carb to the distributor.
Depending on what's left, you may have lines to the door on the air cleaner, to a vacuum can or two, likely two off the thermostat housing and maybe some others.
solo pilot
39
01-16-2014 11:16 PM
littleme13
04-13-2006 09:17 PM
quentinorciuch
07-23-2004 06:37 PM
mdan575
11-25-2003 03:18 PM
