Recalibrating 350 TPMS
Really considering getting a 350 vs the 250 I was initially considering. The 350 rides just a little rougher, but I think the mileage will be very comparable. Stock the 350 specs out the TPMS at 80 PSI rear... I'm sure this has a bit to do with it riding rougher in the rear vs the 65 PSI spec on the 250.
Am I correct in assuming that I can adjust the set point value on the 350 with the Forscan software? Looks like it's listed in the spreadsheet, but I didn't see anyone confirming it can be done.
Dropping the rear tire pressure when unloaded would be great for the times the higher payload isn't needed!
I have been experimenting with pressures on the rear. I am down to 68 cold, with no alarms.
I have heard 65 brings alarms, but posted above says down to 60.
I would be happy with 60, until I buy a new computer to run FORscan and change it.
If the value is changed with FORscan, what range would keep from triggering the alarm?
+/- 10?
+/- 10?
+/- 10?
+/- 10?
on
Can you provide instructions on how to reset the TPMS thresholds in the dash? It's not possible on any truck I've seen. You have to use FORScan or a similar tool to change the module ID values.
http://www.fordservicecontent.com/Fo...ngEnabled=True Go to the reset procedure. Let me know if it works.
+/- 10?
+/- 10?
I changed mine to 50 psi rear, i run 65 front 50 rear empty and light towing/hauling have had great luck thus far
on
