Recalibrating 350 TPMS
Old Jan 2, 2017 | 04:44 PM
cayenne's Avatar
cayenne
Really considering getting a 350 vs the 250 I was initially considering. The 350 rides just a little rougher, but I think the mileage will be very comparable. Stock the 350 specs out the TPMS at 80 PSI rear... I'm sure this has a bit to do with it riding rougher in the rear vs the 65 PSI spec on the 250.
Am I correct in assuming that I can adjust the set point value on the 350 with the Forscan software? Looks like it's listed in the spreadsheet, but I didn't see anyone confirming it can be done.
Dropping the rear tire pressure when unloaded would be great for the times the higher payload isn't needed!
Old Jan 2, 2017 | 05:12 PM
screwy's Avatar
screwy
Yes you can, I have dropped mine to 65psi in the rear with forscan.
Old Jan 2, 2017 | 05:43 PM
CGA's Avatar
CGA
On a recent trip I ran my 350 at 60 psi cold front and rear with no alarms. After taking the rears up to 80 to carry a load we did have a rear flat and the alarm came on at 58. YMMV
Old Jan 2, 2017 | 09:03 PM
EpicCowlick's Avatar
EpicCowlick
There have been multiple confirmations of the TPMS adjustment on the FORScan Codes spreadsheet.
Old Jan 3, 2017 | 07:10 AM
69cj's Avatar
69cj
I just asked my dealer to drop the trip point down to 50 psi so that I could drop the pressure when empty.
Old Jan 3, 2017 | 07:22 AM
user 474747383's Avatar
user 474747383
The spec's on my 17 250 are 75 front and 80 rear .. ?
Old Jan 3, 2017 | 07:39 AM
kylant's Avatar
kylant
I have been experimenting with pressures on the rear. I am down to 68 cold, with no alarms.
I have heard 65 brings alarms, but posted above says down to 60.
I would be happy with 60, until I buy a new computer to run FORscan and change it.
If the value is changed with FORscan, what range would keep from triggering the alarm?
+/- 10?
Old Jan 3, 2017 | 10:17 AM
AK_SuperDuty's Avatar
AK_SuperDuty
+/- 10?
I'll have Forscan going on Thursday after I'm home from work. I will set my TPMS setpoints to 55 psi all the way around. I want to run my tire pressures at 65 all the way around unless I'm towing, then I will set my rears to 80.
Old Jan 3, 2017 | 10:45 AM
cayenne's Avatar
cayenne
I believe the 250 set points are determined by the payload package. Yours may have the heavy duty payload option?
Old Jan 17, 2017 | 04:37 PM
Mixerman90's Avatar
Mixerman90
The owners manual explains how to adjust it with without any special tools. It's all done from the dash.
Old Jan 17, 2017 | 04:50 PM
EpicCowlick
Can you provide instructions on how to reset the TPMS thresholds in the dash? It's not possible on any truck I've seen. You have to use FORScan or a similar tool to change the module ID values.
Old Jan 17, 2017 | 06:25 PM
Mixerman90's Avatar
Mixerman90
http://www.fordservicecontent.com/Fo...ngEnabled=True Go to the reset procedure. Let me know if it works.
Old Jan 18, 2017 | 06:04 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
+/- 10?
i found on my truck, sustained psi below 65 will trip the alarm, if you take off on a drive with 64 psi cold rear and in a few miles they are up to 66 then it wont trip,
I changed mine to 50 psi rear, i run 65 front 50 rear empty and light towing/hauling have had great luck thus far
Old Jan 18, 2017 | 06:07 AM
KubotaOrange76
all i saw was how to reset the system after a tire rotation?
Old Jan 18, 2017 | 01:30 PM
EpicCowlick
Ok, this is the reset procedure to perform after rotating tires. I thought you were talking about changing the actual psi thresholds from factory settings. I changed my thresholds from 65/80 front/rear to 55/60 front and rear with FORScan. There's no way to do that with the features in the dash.
