390 swap into 73 4x4
Old 12-05-2016, 07:01 AM
Snowking's Avatar
Snowking
Snowking is offline
Hey all.
So I have a 73 4x4 halfton. Currently has a blown 300 motor with a 4 spd manual.
Friend found me a 2wd 1 ton truck with a great 390 and a 4 spd manual
Does anyone know if there is a way to make the 300 transmission fit into the bellhousing from the 390? I also have a FE 4x4 trans but not sure what kind of shape it's in.
Thanks in advance
Old 12-05-2016, 10:43 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,598 Likes on 1,303 Posts
It might bolt right up. Both transmissions should have the Ford "butterfly" rectangularish pattern. Input length, pilot size and input spline need to be verified as well.
The FE bell housing pattern is different than the six, but the transmissions that do not have integral bells all have the same pattern since 1965.
Old 12-06-2016, 04:07 AM
jowilker's Avatar
jowilker
jowilker is offline
Snowking, Know this, your friends 1 ton could likely have a FE engine in it 352/360, that unless built and installed by owner IS NOT a 390.
All FEs become 390s on sale day.
John
Old 12-06-2016, 07:34 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Why not use the tranny from the donor truck?
Old 12-06-2016, 10:08 AM
Snowking's Avatar
Snowking
Snowking is offline
That's a 2wd transmission, unless I can use that to bolt up to transfer case
I believe all 3 trans are np 435. My parts truck is a 73-75
Valve cover sticker says 390 but never know
Old 12-06-2016, 10:33 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Ah. I believe you'd have to change the tail shaft. I keep forgetting that other 4x4's didn't have a divorced transfer case like my highboy
So in that case, your 435NP should bolt up to the 390 bell, but I'm not sure about the input shaft. Best to compare.
Old 12-06-2016, 12:19 PM
Snowking's Avatar
Snowking
Snowking is offline
Ya unfortunately mine is married.
And yes as long as I can make one good transmission that'll work for me is all I need. Only kicker is I know tran in the 390 is a great working one. One on my 4x4 I think is ok but not sure.
Old 12-06-2016, 12:35 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
To change over the output shaft of the 435NP, you'll have to take it entirely apart. Stick with what you have
Old 12-07-2016, 02:28 PM
Destroked 450's Avatar
Destroked 450
Destroked 450 is offline
Unless you truck is lifted you'll need a 4x4 oil pan, pickup tube and dipstick, the engine will fit but with a non 4x4 pan the first time you bottom out the left front the diff housing will put a big dent in the pans sump.
Old 12-08-2016, 06:07 AM
Snowking's Avatar
Snowking
Snowking is offline
Very good to know! Sounds like a good reason to get a lift to me haha
How high of a lift would I need?
I guess I do have a 360 in my parts 4x4 chasis too tho
cowboy.2010
04-10-2010 03:22 PM
jamie_lind2006
Engine Swaps
06-17-2007 12:19 PM
Michael Sizemore
15
06-16-2005 02:22 AM
Sierra94_
12-19-2003 12:05 PM
66MercMan
07-10-2003 05:00 PM
Quick Reply: 390 swap into 73 4x4
