Fuel gauge working but not accurate
Thanks for asking. I had forgotten about this post. I don't think I had ever filled the tank full. I have a filling issue. I have never put over 10 gallons at time in the truck. It takes approximately 30 minutes to pump 10 gallons. If I drove it regularly I would be crazy by now. After pumping 10 gallons the gauge reads above full. After 100 miles it reads 1/4 full. I never have driven it beyond that before filling it up. It has a new filler neck hose and vent tube.
Firewall to cylinder head
There was a small gauge wire, factory installed, that ran from the rear of the drivers side head to the firewall. Both mounting bolts were fairly good size, so I replaced the wire with a battery cable from O'Reilly
before attaching the cable to the firewall, I sanded it down to bare metal.
