2X. I think it is either a bad switch or someone hacked in to the wiring leading to the switch to also power something else. In the schematic above, the wire connecting to the H/L switch marked circuit "25" is a 12V constant power source. So you need to check the wiring. If everything is OK then change the switch. You don't want this problem to shoot your truck up in flames.
Painless and American Autowire are more GM-oriented but usable.
I wired two vehicles using Painless. The kits are pricey and you have to know how to read a meter but they work. They make kits for however many circuits you need. Twenty-four will work for your truck.
I had the same problem with my 70 Short bed, while the switch is more than likely the problem, mine was the hi-beam switch. I swapped it out and everything worked.
Also, check out ebay for a harness. I didn't have the cash to install a new harness, so I looked at eBay and found a mint harness for $100, no splices and it's in great shape.
