Got my zf6 swap done- still have auto transmission codes
I finally got my tranny swap done, thanks to a lot of great info here. Took it for a spin last night and all was well- or so I think. I have a cel and I scanned codes and bunch came up for the auto trans... Shift solenoid, temp etc, I was told that the Pcm I bought with the parts was for a manual, but would it still throw those codes? Even with a manual pcm? I didn't think it would. I could be wrong. The casing for the " manual " Pcm had a hole for a ts chip- maybe the PO just had a ts re burned? Any thoughts? I didn't think a manual pcm would throw auto codes.
Thanks
Thanks
on
Thanks
Thanks
Yes, this will tell us if it is an auto or manual PCM. It sounds like the typical case of running an auto PCM with a manual trans swap. Get a bunch of codes, the acc pedal does work right, etc.
If it does end up being an auto PCM, we can flash it to manual... https://www.dp-tuner.com/ford-powers...nce-flash.html
