Intermittent loss of power (momentarily stuttering)
Intermittent loss of power (could be describe momentarily stuttering) with momentary illumination of the check engine soon light. Its only happened a couple of times. Maybe about a year ago (I changed the fuel filter after it occurred). It occurred again about a month ago and then again yesterday. About a month ago I had a friend with a scanner look at the codes and he said there was only one and it was for low fuel pressure. Its been maybe 5k since I changed the fuel filter.
The truck is driven intermittently, maybe 5k or 6k a year, and usually parked with a full tank of fuel.
Any suggestions on areas I should look at to correct this?
I got my stock 2001 F350 4x4 manual transmission in 2004 with about 157k miles. Today I've got about 228k miles.
Change fuel filter again. If pressure is low. If in a South area you could get algea that will show on filter like slime.
Do you know the code number that was thrown? Reason I ask, is there is not a code which indicated low fuel pressure. The PCM does not monitor fuel pressure, so it really doesn't know if it is low. There is, however, a code for low high pressure oil, which is pretty common to see.
64F260
04-30-2010 05:23 PM
grantpage
03-30-2010 07:59 PM
