2015 6.7 low fuel pressure
I know it's posted a few places but I have a reoccurring problem. Whenever my truck goes below 100 miles of remaining range the low pressure light comes on. Within 10 miles the reduced engine power comes on.
First time at 11k miles, at the dealership for 4 days, test fuel filter for crystalization, tested the diesel fuel, checked for leaks and then reset the codes and gave it back to me. Said it only popped the code for low bank 1 pressure.
Now 12,800 miles, driving home from work. 87 miles remain on range, pulled in a gas station and the low pressure light comes on. Threw 25 gallons in it and made it about 15 miles. Currently sitting in a Walgreens parking lot waiting for a tow truck with the low engine power light on. They will only tow it halfway to my house to a dealership since I am out of road side assistance range.
Circumstances right now, its 65 outside so it's not gelling like many other people. I can here the pump running and it spooled up real high when I tried to restart it but did not fire. Grabbed the code reader and it had 8 general codes all for low fuel bar pressure.
Pretty happy that I dropped almost 60k on a truck that hasn't even made it a year yet and not even 13k miles on it
Thanks Tom
Funny thing is the first dealership said they checked everything, I hope it's something that easy to repair.
Please let us know what happens.... Obviously something is wrong and needs replacing. Not that I am all knowing, but I haven't heard of going low in fuel and getting a reduced power message. I normally keep my tank more than 1/2 full on my 2015. Mainly because it's so cold out here and the temps change drastically that I am afraid of condensation so I keep the tank filled up.
I will update as soon as I find out
I just had this happen to me on Thursday. So first thing to do is change fuel filters, sometimes they don't seal and cause air to get in the system I think it's the o ring that gets dried out or just doesn't seal properly. There is a YouTube video on how the pump sounds when there is air in the system. Second check for leaks, check the low pressure fuel pump, its on the frame rail it's part of the filter, with truck running check carefully around the pump for small leaks, I think mine is leaking because I see stains on the transfer case. Check the fittings by the filter under the hood.look for small leaks or even evidence of fuel spraying, there were complaints on earlier models with faulty fittings. I am going to replace the pump myself, $253 on Amazon and can be done with basic hand tools in probably 30 minutes. I might even carry a spare pump but will definitely carry an extra filter kit. I don't like my truck at the dealer for days when I can do it myself in a very short period of time.
To Travis, as well as all other 6.7L truck owners, may I suggest you all read this article, titled "Fuel Additive Bottle Caps":
Diesel Technician Society
I, a Ford dealer technician as well as a current 2016 F-250 6.7L owner made the very mistake described in the article referenced above. It was extremely embarrassing happening to me as this on a weekend while I was out running an errand. As humiliating as it was, having to arrive at my workplace with my truck on a flatbed tow, thankfully the fix turned out to be the very thing referenced above. So the moral of the story is? Those of you running fuel additives, more specifically the Motorcraft PM-22 and PM-23 additives, be careful not to allow the bottle cap cardboard disc fall into the fuel filler as I happened to be dumb enough to do, evidently. Since then, I now have five individual jars that I separate each new bottle of product into, ensuring that I don't repeat this mistake again.
Dealership
Checked all my bottles
I checked the bottle of 22 that I have open cardboard still in it, well was still in it. Dealership called today, can't figure it out. I sent them photos of all the codes I found and photos of the warnings on the dash. They said they can't find the problem and are talking with Ford (again).
prestigeworldwide
6.7L Power Stroke Diesel
29
02-07-2022 05:07 PM
Mystic_Cobra
83
12-22-2017 07:19 AM
cpetras
10-23-2016 10:55 PM
