Trouble shooing TBC Fault
Texastech_diesel hooked me up with a link to a site that fixes the TBC on mine....05 F350 DRW. So I went to pull my unit out and noticed the wiring was unhooked. I thought that I couldn't be lucky enough that a simple snap in of two plugs would do that trick. It didn't. TBC didn't even light up. So dug some more into it and found the 30A fuse was missing. I robbed one and the started the truck. TBC lights up and looks like it's working (haven't tested at the trailer wiring yet) but now I'm also getting a Trailer Connection error on the dash in addition to the same TBC Fault even though it powers up. Previous owner obviously had an issue and just unplugged it all. I've read and read on here about what to check and can't narrow it down. I tried to pull the codes, but for some odd reason my ODBII scanner won't find the truck
I'm going to send my TBC in to at least have them look it over, but will that also give me the Trailer Connection error I'm now seeing? Where else do I look? I've got a camping trip in the mountains of WV this weekend and really need some brakes.
Very true Fiz. I should have stated, I just got the truck and have yet to hook up a trailer to it. It was sitting in my garage when those codes came up. Well...the TBC came up while traveling back home from buying the truck, but that was only on start up and once Reset it was good till the next start.
Check the wiring and the 7 pin in the rear. You can use a test light to check for power to 7 pin the 2 bottom terms are ground and brake. put a test light to them and hold the brake down and see if it works. Ive had a few with green cheese at the bottom 2 pins.
I also had an 05 F450 last year that had a cluster problem I swapped clusters (ford reman) and got the tbc fault every time you first started it, but trailer brakes worked and you had to clear the message every time you started it trailer on or not.
I will certainly check that. Thank you. I had to send the TBC off to get worked on today in order to get it back in time for this weekend. Fingers crossed that it was the entire problem. I did test the 7 pin today, just not for brakes. But luckily none of it was corroded.
check that too? That is where they can have hidden corrosion that will
mess with you.
Just get under the rear bumper and unhook the back side connector.
After you look at it is it's clean spray with contact cleaner and then apply
some dielectric grease to sean out any moisture from the contacts.
Sean <BR>
6.0L Tech Folder
On the 7-pin did you remove the connector on the back side and also
mess with you.
Sean <BR>
6.0L Tech Folder
mess with you.
Sean <BR>
6.0L Tech Folder
My TBC controller will be in tomorrow. I will certainly report back once I get it in.
Good point. Someone has spliced in wiring for a 6 pin for a goose neck. I check it out the other day. Wasn't that bad looking but ya never know...
I should be able to post you a wiring diagram later to night.
2005 F350 DRW I think should cover it.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
