Use of courtesy time out
Planning to get a set of dual white and amber LED's to mount on the step rails
I got the Ambers figured out to be running and turn signals.
What I am struggling and looking for some help is that I want to have the white LED's come on just until I get to the vehicle and then shut off
Thinking of using the courtesy timer circuit for that but have no clue where/how to access
The other option is using a control signal that I would tap off when the vehicle is removed from park
Help in either of those plans or suggestions for another method are greatly appreciated
Since they're led lights we're talking about very low current draw right? I would just tap into the wire harness that lights the third brake light/cargo lights on the back of the cab. Just need to find the wire color in the light housing and then trace back to under the cab or in the footstep trough in the door jamb.
Plus side, you would get a nice fade out when the courtesy timer times out.
Yes very low current draw
Thx!
Take a look at the install instructions for AMP power steps. Mine came with small LED lights to go under each door and they are all triggered from the door wires that get tapped under the front passenger sil plate. The AMP setup powers them through their own controller, but the trigger is coming from the aforementioned wires.
