Correct Oil for V10
Correct Oil for V10
Recently purchased a Motorhome with a 2002 V10 engine. I had the oil changed at Camping World and asked beforehand if they knew the correct oil to use,not to insult, and the answer "we certainly do". When I picked up the MH the service order read 10-30 oil was used. I spoke with the Service Mgr and told him they used the wrong oil---that Ford manuals call for 5-20 and even the oil filler cap has 5-20 on it. He said 10-30 is the correct oil for this engine definitely. I asked him to show me proof and he was unable to produce that info.
I guess I should call Ford and ask but I thought the forum might have something to add. Is it possible for the 10-30 to hurt the V10 for 3000 miles? Does anyone now use 10-30 in one of the newer V10s.
Correct Oil for V10
You will get a bunch of answers on this, you shoud see the same question asked on a motorcycle site.
In the end you will hear
Synthecis suck they runed my motor
Svnc's are great I go 500,000,000 miles and never touched a prat
Hevy weight sucks it will burn your motor
light oil sucks it will burn your motor
And on and on and to a man my self included don't know squat!
We only know what we believe. Now the best advice ever given to me was by a Rcrd Rep. "We have never had an oil related failure is you run the latest API rated oils that meat or exceed Fords recomendations, and change your oil on schedule."
Correct Oil for V10
Correct Oil for V10
Okay guys, to add to the confusion; I was always told to run a heavier oil in a high mileage engine. My truck has almost 90k on it. What oil viscosity is recommended. (I also live in Florida, so no severe cold temps)
BTW, I have used Castrol for years with no problems. Any comments about Castrol oil?
