Replacing Head Gaskets
I have a 05 F250 6.0 and I am going to do a cab on head gasket replacement in a few weeks. I am looking for a step by step guide to doing this. If you know of any links, recommend a shop manual or have some helpful advice, I would much appreciate it before I take on this project.
You might want to talk with "got2befast". He is in the middle of this right now.
Here is the thread he is currently working.: https://www.ford-trucks.com/forums/1...d-removal.html |
Thanks for the reply. Checking out his post.
Are the factory shop manuals worth the cost? Are they well written and give good step by step instructions?
you can by a factor dvd (or copy) on ebay. yes the oem dvd is worth its weight in gold. Thats the only book woth it.
Thanks for chiming in cheezit...as I had no clue!
Cheezit, I use an apple computer and usually the DVDs are on PCs only. I was wondering about the Ford factory workshop books. Comes in volume 1 & 2 and a wiring diagram.
Thanks! |
I have some links, give me a sec to post them :)
dont know about the apple issue. I sure there is a workaround with an emulator maybe one of the it guys can help there.
so far as what one to get well I would get the set. We use the online books so we dont even need to deal with the dvd's |
Smokersteve,
I will be going thru the links next week and I am sure they will be a lot of help. Thanks! |
Originally Posted by holdendaniels
(Post 9439465)
Smokersteve,
I will be going thru the links next week and I am sure they will be a lot of help. Thanks! Your welcome :-wink |
After doing some research and my bed plate leaks a little oil, I decided I am going to do a cab-on engine removal so I can replace the head gaskets, front and rear main seals, and the bed plate.
Thanks for the responses I received! |
I am in the process of replacing my head gaskets. I have removed my engine so far. If you want to follow the progress here is the link:
https://www.ford-trucks.com/forums/1...d-gaskets.html |
