Replacing Head Gaskets - Ford Truck Enthusiasts Forums
Old 10-13-2010, 02:36 AM
holdendaniels holdendaniels is offline
holdendaniels is starting off with a positive reputation.
I have a 05 F250 6.0 and I am going to do a cab on head gasket replacement in a few weeks. I am looking for a step by step guide to doing this. If you know of any links, recommend a shop manual or have some helpful advice, I would much appreciate it before I take on this project.
Old 10-13-2010, 06:55 AM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is online now
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
You might want to talk with "got2befast". He is in the middle of this right now.
Here is the thread he is currently working.:
http://www.ford-trucks.com/forums/10...d-removal.html
Old 10-13-2010, 11:43 AM
Thanks for the reply. Checking out his post.
Old 10-13-2010, 12:16 PM
Are the factory shop manuals worth the cost? Are they well written and give good step by step instructions?
Old 10-13-2010, 06:33 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
you can by a factor dvd (or copy) on ebay. yes the oem dvd is worth its weight in gold. Thats the only book woth it.
Old 10-13-2010, 06:56 PM
Thanks for chiming in cheezit...as I had no clue!
Old 10-13-2010, 07:34 PM
Cheezit, I use an apple computer and usually the DVDs are on PCs only. I was wondering about the Ford factory workshop books. Comes in volume 1 & 2 and a wiring diagram.
Thanks!
Old 10-13-2010, 07:35 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
I have some links, give me a sec to post them
Old 10-13-2010, 07:50 PM
cheezit's Avatar
dont know about the apple issue. I sure there is a workaround with an emulator maybe one of the it guys can help there.
so far as what one to get well I would get the set. We use the online books so we dont even need to deal with the dvd's
Old 10-14-2010, 02:03 PM
Smokersteve,
I will be going thru the links next week and I am sure they will be a lot of help.
Thanks!
Old 10-14-2010, 05:59 PM
Quote:
Originally Posted by holdendaniels View Post
Smokersteve,
Thanks!
Your welcome
Old 10-24-2010, 08:56 PM
After doing some research and my bed plate leaks a little oil, I decided I am going to do a cab-on engine removal so I can replace the head gaskets, front and rear main seals, and the bed plate.
Thanks for the responses I received!
Old 11-13-2010, 03:11 AM
I am in the process of replacing my head gaskets. I have removed my engine so far. If you want to follow the progress here is the link:
http://www.ford-trucks.com/forums/10...d-gaskets.html
Oil Pan gasket replacement Trstrugar 1987 - 1996 F150 & Larger F-Series Trucks 1 02-21-2017 08:55 PM
2003 5.4L headgaskets maxtruck00 1999 to 2016 Super Duty 1 07-10-2015 12:31 PM
Head Gasket Replacement 2006 F250 6.0 frogjaw 1999 to 2016 Super Duty 5 07-12-2013 01:33 PM
Exhaust fumes in the radiator. 2001-ranger Ranger & B-Series 6 10-05-2010 10:21 PM
'90 F-150 5.0L head gasket leak prettygooddeerhunter 1987 - 1996 F150 & Larger F-Series Trucks 6 02-05-2009 07:00 PM
Tags
03, 2006, 60, f250, f350, ford, gasket, gaskets, head, headgasket, install, installation, powerstroke, replace, step
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
