- 85 Ranger Distributor
- Thermostat, or temp gauge failing?
- PCM trouble code PO340 help needed
- How Can Iget More Horsepower
- what years 4.0 fit my explorer
- Required Service for 2.9??
- What's wrong with my P.O.S.
- ranger missing
- CEL on- code is 0141, 02 sensor heater malfunction- help???
- stallin when driving and looking for headers
- Low Idle/IAC problem with '96 4.0L Ranger
- 2.3 liter turbocharged diesel
- Still Missing - What's Up?!!
- starting problems with 4.0L
- 2.9 liter stuck on high idle
- Big fuel problem
- Code 124 troubleshooting
- Serpentine Tensioner
- Lower intake manifold leak
- How do you adjust (TPS)? on 4.0L
- Looks like rust but it isn't
- Torquing 4.0L Cylinder Heads
- help with vaccum lines on 4.0L intake
- Air diverter good, still backfires
- Changed plugs and wires 4.0!
- 87 Bronco II 2.9 RPMS go up and down
- Need suggestions air filter setup
- Replace oil pump
- 91 4.0 missing badly during acceleration
- Replace water pump on 4.0L 93 Ranger w/120K miles if I have the radiator out?
