05 f350
10-06-2010, 12:32 PM
05 f350
what is the fuse number of fuel pump and ficm ?thanks
10-06-2010, 02:21 PM
on
The fuel pump fuse is #40 (20A) in the passenger compartment and the FICM is #5 (50A) in the power distribution control box on my 2006.
The FICM also has a logic fuse as shown below.
10-06-2010, 03:56 PM
10-06-2010, 05:38 PM
fusses ok - ficm 48 volts - has fuel pressure but now just crank and no start -
10-06-2010, 05:46 PM
Try disconnecting the icp connector and then starting.
10-06-2010, 05:55 PM
when cranking the oil pressure doesn't show oil pressure , is that ok ?
10-06-2010, 06:09 PM
desconected the icp and no start .
10-06-2010, 06:11 PM
Do you have any codes? If not it could be a bad stc fitting in the hpop system.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
1986 ,
2006 ,
2007 ,
73 ,
box ,
distribution ,
escape ,
f250 ,
f350 ,
ficm ,
ford ,
fuse ,
hybrid ,
location ,
locations ,
power
