Why the big leaf spring loop?
Old 10-06-2010, 10:04 AM
swooshcmk's Avatar
swooshcmk
swooshcmk is offline
Ok, I don't know the answer, I gotta ask...
In the stock front leaf springs the rear of the springs have a big loop of the lower spring around the upper spring, as seen in the stock top spring on the right side in the picture here:
What's the purpose of this loop? I don't envision it doing anything in particular under compression. Perhaps it has a use when you get airborne off a big jump?
The reason I ask is because I'm doing a shackle reversal and the loop is hitting the shackle... Do I need the extra loop for an unforeseen reason or can I loose it?
Thanks guys!
Old 10-06-2010, 12:13 PM
Cruickie's Avatar
Cruickie
Cruickie is offline
That is a good question.... I am now curious! Hopefully someone will know or atleast have something that sounds right!
Old 10-06-2010, 01:47 PM
cleatus12r's Avatar
cleatus12r
cleatus12r is online now
Butt-Head
Received 1,975 Likes on 1,108 Posts
Without taking the time to type it all out....
What is a military wrap on leaf springs? - Yahoo! Answers
Old 10-06-2010, 03:40 PM
swooshcmk's Avatar
swooshcmk
awesome, I didn't know that. Thanks!
So ideally I'd move the military wrap to the front since the shackle is moving to the back and then re-drill the locating pin in the 2nd leaf. Slight possibility of weakening the 2nd leaf with the additional hole so make sure it's deburred and filed smooth. I could also throw in the extra leave I have as well for extra support..
Any thoughts?
Old 10-06-2010, 05:01 PM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
the big loop is so if the top leaf spring brakes, it will hold in place still
Old 10-06-2010, 05:02 PM
oreocreaming
and the end with the big loop is always forward
Old 10-06-2010, 05:06 PM
swooshcmk's Avatar
swooshcmk
Yup, but is there any issue with flipping and redrilling the locating pin on the 2nd spring so I can move the the loop to the solid spring mount?
Old 10-06-2010, 06:42 PM
eraser5's Avatar
eraser5
eraser5 is offline
No it is not. The loop should be at the fixed and of the spring. On a stock IFS that puts the military loop at the rear of the front spring.
Old 10-06-2010, 06:54 PM
swooshcmk's Avatar
swooshcmk
That's correct Eraser5. However in doing the front shackle reversal I'll be moving it to the front. And unless someone says "NOOOO DON'T RE DRILL THE LOCATING PIN" in the next hour or so I'm going to spin the 2nd spring so they'll be located up front.
Thanks for the help guys. Learn something new every day.. and today I've learned a few things so it's been a good day lol
Old 10-06-2010, 08:08 PM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
What's wrong with fliping the entire pack end for end? The center pin not in the exact center?
I really don't know...
Old 10-06-2010, 08:15 PM
swooshcmk's Avatar
swooshcmk
Yeah the locating pin is about 4" off center. If you flip them end for end the axle will get moved forward 4"
Old 10-06-2010, 09:12 PM
oreocreaming
ya, and every loop leaf ive had the loop is on the front of the leaf pack.
Old 10-07-2010, 06:09 AM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
Ok, flipping it won't work. What about a custom build shackle? Could give you a little lift too...
Old 10-07-2010, 10:12 AM
oreocreaming
if you do a custom shackle, then your knuckle angle will be downward. your steering will be terrible and you'll get death wobble like crazy. you'd have to throw a shim or two in there to bring it back to -5 degrees assuming your shackle is up front still. if you do the reversal kit and put it in the rear, then you'll be fine, but you dont want too much angle or its gonna turn like crap.
jdyal2
1999 to 2016 Super Duty
03-31-2014 07:27 PM
-mywheels-
03-24-2014 08:00 PM
Outlaw56
15
09-10-2013 03:12 PM
Outlaw56
09-05-2013 02:41 PM
mytbtruck
02-28-2011 06:54 PM
Quick Reply: Why the big leaf spring loop?
