oil in the air box, and lots of it?? cant figure out why?
Old 10-09-2010, 09:13 AM
79 f-150 guy's Avatar
79 f-150 guy
79 f-150 guy is offline
ok i have a 1989 bronco with 112,000 miles on it. it is in great shape and runs crisp, realy sounds a feels good but today when i pulled the air filter out i realised the air box was full of oil and it is so full that it is dripping out the tube and coating the inner fender.. it is a quart or more low and it disnt burn oil.. why is all this oil in my air box, it is coming into the box from the tube off the valve cover... anyone know what is causing this, i'm stumped. thanks
Old 10-09-2010, 09:19 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Have you changed the PCV valve lately? And checked the hose going to the PCV valve for vacuum?
Old 10-09-2010, 09:30 AM
79 f-150 guy
i just swapped that out, literaly 5 minutes ago rite after posting up. but it had a new one in it that the last owner had just installed..
Old 10-09-2010, 09:33 AM
White 97 xlt
Did you check to make sure there is a good airflow to the new valve? Those lines are bad to get "carbon" or some kind of junk built up and plug the line off....
Old 10-09-2010, 02:48 PM
Big-old-460's Avatar
Big-old-460
Big-old-460 is offline
YOU HAVE SOMETHING CALLED BLOW BY . its when your rings are worn and the oil is getting past the rings and valves, in the heads and what end up happening is your truck will start to exhale out the air box, it is very common thing, also your Pcv needed to be replaced,...
common fixes Clean air box, replace pcv valve and hose,
clean heads, check for compression in your cylinders, you prolly have one or more that putting out bout 100 or less psi
due to old worn rings,
also check your manifold if it is full of oil, The ONLY cause is blow by from the rings to the valves ,
good luck if u need any advice or help let me know
ttul
jayson
p.s blow by doesn't burn oil . just spits it around .
Old 10-09-2010, 08:44 PM
732t37's Avatar
732t37
732t37 is offline
Well obviously you have a serious problem with the PCV system or the upper end, maybe both. I'm leaning towards PCV, I don't think oil in the air box would be his biggest problem if he had that much blow-by. It should burn at least some oil if the upper end is the problem. But definitely check it while you're fixing the PCV system.
IMO there's a 75% chance this is a PCV valve, which is often a 5-minute fix BUT Ford gets hundreds for them. Get one from NAPA or a really, really, good used one.
Old 10-09-2010, 08:48 PM
79 f-150 guy
i just cant see it being blow buy, it rums perfect all the time.. it is a little lazy "dosnt seem to ave alot if power" but i think thats mainly becouse it's 100% stock rite now down to the factory ford cacat and exhaust..
Old 10-09-2010, 08:56 PM
732t37's Avatar
732t37
732t37 is offline
Yea most guys I know had to replace those valves at 90,000 or so and they had problems similar to yours. I have 180,000 on mine and it does leak, I just don't give a crap because it's only about 1 fl oz every 1,000 or so.
Old 10-09-2010, 09:00 PM
86F150302's Avatar
86F150302
86F150302 is offline
Do a compression test.
897.3idi
02-02-2012 11:23 AM
mcboudreaux
10-03-2010 11:51 PM
goodwrench
04-27-2010 02:10 PM
Doug76
1978 - 1996 Big Bronco
08-08-2005 11:55 AM
Randoo
06-19-2003 10:42 AM
Quick Reply: oil in the air box, and lots of it?? cant figure out why?
