I'm trying to find a common point for all of those systems and I can't see one other than a partial loss of main power. This could be due to a faulty ignition switch, a bad wire connection point, a problem in the fuse box, etc. Have you tested for power at the fuse terminals in the fuse box? (Note: Some of them will only have power when the key is on.)
Is there a device to test the fuse terminals in the fuse box. Plus, I forgot to mention the interior lights do not illuminate with opening of the doors, but will when key is removed from ignition. I thank you for your assistance.
