Checking rear diff fluid level
Old 10-04-2010, 01:13 AM
Brandynr's Avatar
Brandynr
Brandynr is offline
I apologize if this question has been asked before, but I couldn't figure out the search words to find it...
I have a '78 F150 with axle code H2J; I understand this to be a Ford 9" rear axle. I'm trying to figure out how you check the rear diff fluid level, or even change the fluid. Any help is greatly appreciated.
Old 10-04-2010, 01:31 AM
bobwires's Avatar
bobwires
bobwires is offline
these axles are great for strength, TERRIBLE for convenience.
yank the wheels and rear brakes, unbolt the axle plates and slide the axles out. drop the driveline and unbolt the carrier. replace the seal and bolt the carrier back on when the fluid is drained and wiped clean. fill up to the fill plug.
Old 10-04-2010, 08:57 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
The level is check through the fill hole. On the drivers side of the differential housing there is a 1/2" pipe plug. Remove the plug, oil should "dribble out" of the hole, if it doesn't add oil till it does.
Some (very, very few) have drain plugs. You can try a suction gun or, as bobwires suggests, drop the center section.
On yours, if the axle code is correct, you have a limited slip rear. Be sure to use the correct oil.
Old 10-04-2010, 11:40 AM
Brandynr's Avatar
Brandynr
Brandynr is offline
Thanks guys.
Mike, I didn't know it'd take a certain kind of oil... What do I need?
Old 10-04-2010, 12:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Mobil 1 synthetic LS75W90 is a good one (note the LS prefix), you can use regular gear oil if you add a friction modifier to it. You should be able to get the additives at any auto parts store.
Just tell them you need oil for a limited slip rear, it should say on the bottle that it can be used in limied slip applications.
Just incase you don't know already H2J= (H2) Ford 9" 3.50 ratio limited slip 3750 lb capacity axle (J) w/ power steering
Old 10-04-2010, 12:53 PM
Brandynr's Avatar
Brandynr
Brandynr is offline
Thanks again Mike.
nxtdiesel
2017+ Super Duty
06-26-2017 02:13 PM
tacostuff
03-29-2017 11:26 AM
Steven Stocki
11-06-2016 10:42 PM
SuperDutyScaler
1999 to 2016 Super Duty
02-15-2012 11:31 AM
cdherman
1997-2006 Expedition & Navigator
02-08-2011 09:27 PM
Quick Reply: Checking rear diff fluid level
