sterling rear end
Old 09-28-2010, 06:31 PM
aking225's Avatar
aking225
aking225 is offline
sterling rear end
could anyone give me some good solid info about whats good and bad about the sterling 10.25 full float rear end with 3:55, i was thinking about having 3:73s put in but wasnt sure,
Old 09-28-2010, 06:55 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
Pros: Tough, full floating axle
Cons: not a large aftermarket
Old 09-28-2010, 07:04 PM
aking225's Avatar
aking225
aking225 is offline
better than the dana 60?
Old 09-28-2010, 07:18 PM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
Yes, better than D60 rear
Old 09-28-2010, 07:26 PM
79Ford4x4's Avatar
79Ford4x4
79Ford4x4 is offline
yes it is better than the 60 rear. Weak point is the rear cover ( thin stamped steel ). If your not offraoding then thats not an issue. As far as aftermarket there is enough. Detroits, Arb, Eaton, gears to 5.38, axles, disc conversion.
Old 09-28-2010, 07:31 PM
aking225's Avatar
aking225
aking225 is offline
well how good are the 3:55 gears, i dont do any towing but the grunt of the 3:73s would be nice
Old 09-28-2010, 07:40 PM
79Ford4x4's Avatar
79Ford4x4
that's alot of coin for such a slight increase. Why not find a Sterling with 4:10's. Most you'll pay is $150-200 and just swap axles
Old 09-28-2010, 07:46 PM
aking225's Avatar
aking225
aking225 is offline
i only have a c6 though and alot of there area around me is highway or higher speeds, and i know 4::10s only top out at like 60
Old 09-28-2010, 07:53 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I have never had the issue but some say the Pinion nut comes loose due to the sterling has a crush coller
Old 09-28-2010, 07:57 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
This has happened to me... once... in 350K.
Old 09-28-2010, 08:07 PM
aking225's Avatar
aking225
aking225 is offline
thts good to know
Old 09-28-2010, 10:25 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
What engine do you have? My F250 with a 460 and 3.55 gears has done fine all its life. Would I like different gears: yes, but do I think it's poorly geared like the 3.08 gears on the 5.0: absolutely not.
My dad used the truck for 14 years as a farm truck, and the 3.55 worked perfectly fine for him pulling wagons and trailers without any complaints. Seeing as you have a C6 with no OD, I'd venture you'll be fine with 3.55 gearing to balance power vs fuel mileage.
Old 09-29-2010, 09:09 AM
jokerforever's Avatar
jokerforever
jokerforever is offline
Old 09-29-2010, 02:21 PM
aking225's Avatar
aking225
aking225 is offline
i only have a 302 but i didnt come with the truck, it was dropped in
Old 09-29-2010, 10:11 PM
fordman1090's Avatar
fordman1090
fordman1090 is offline
The most common down side of the 10.25 that i have heard of is that when you go over 4.10 gears you start to sacrifice the strength of the gear set. But i dont think that would be an issue unless your running a diesel with 1000ft/lbs of torque.
Also, other consideration are weight and ground clearance, which can be a factor when building an off road rig.
Quick Reply: sterling rear end
