UPDATE: Door panel swap.....
#49
#53
#54
#56
HELP!
OK guys I am in serious need of help right now... I cut my door lock connectors off on my 04 (without remote keyless entry) and i have 7 wires on each side here is what they are. Right now the unlock works but the lock doesn't and it shorted out my 08 lock switch that i had but luckily i have another one but i don't want to short it again.Below is what i have, what do i need to connect it to to make this not short? I really need to get this together, its dark now but if i ant get it together tomorrow morning i wont be able to work on it again until next Sunday which is a major PITA for me right now.
04 Drivers side
Pin 1- Illumination Ground (Black)
Pin 2- Switched common (Black)
Pin 3- Unlock (Pink/ Light Green)
Pin 4- Hot all the time (Red/Black)
Pin 5- Switch Illumination (Pink)
Pin 6- Not used
Pin 7- Lock (Pink/Yellow)
Pin 8- Ground (Black)
04 Passenger Side
Pin 2- Unlock (Pink/Light Green)
Pin 3- Unlock (Pink/Orange)
Pin 6- Not used
Pin 7- Lock (Pink/Black)
Pin 8- Lock (Pink/Yellow)
08 Lock Both Sides
Pin 1- Lock
Pin 2- Fuse-41
Pin 3- Unlock
Pin 4- Ground
It seemed pretty straight forward but apparently I'm doing something wrong because I'm frying switches, the passenger side is what really confuses the f*** out of me, i had the +12v hooked up with the lock wires on both sides (PK/LG and RD/BK) and the illumination was hooked up to Pin 2 on the 08 connector (Fuse-41) then i had all the grounds tied together and the unlocks hooked up the the unlock pins on the 08 connectors.
04 Drivers side
Pin 6- Not used
04 Passenger Side
Pin 6- Not used
08 Lock Both Sides
Pin 1- Lock
Pin 2- Fuse-41
Pin 3- Unlock
Pin 4- Ground
#59
