2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Changing 12v outlets to Ignition-Switched?
Old 02-08-2010, 06:14 AM
chuck s's Avatar
chuck s
chuck s is offline
Exclamation Changing 12v outlets to Ignition-Switched?
Anyone have a method (hopefully quick and easy) of changing the 12v outlets in the passenger compartment from On all the time to ignition controlled?
It's a PITA to have to unplug my GPS and microwave radio receivers all the time, but if I don't the battery voltage drops very low over the weekend and can require a jump start.
Any assistance appreciated! (I have the same problem in my Explorer, but we'll start here.)
-- Chuck
Old 02-08-2010, 09:27 AM
hjsimpson's Avatar
hjsimpson
hjsimpson is offline
Maybe adding an on/off switch to the outlet, but on the other hand if your gonna take it apart to add the switch might as well convert them to ignition switched.
sorry.
Old 02-08-2010, 09:31 AM
Mark_A.'s Avatar
Mark_A.
Mark_A. is offline
find a key on power under the dash and run a relay to the outlets u want to be key on ... its not easy but if u really want it that bad its possible lol ... or u could get a battery tender those things work great just gotta remember to plug it in
Old 02-09-2010, 06:23 AM
chuck s's Avatar
chuck s
chuck s is offline
I've got a Priority Start on both vehicles so the vehicles always start as this device cuts out the battery when the voltage gets too low. Still looking for a spot on the harness or fuse box to transfer the outlet leads.
-- Chuck
Old 02-09-2010, 07:53 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
The solution I did in my 06 explorer, my 07 expedition and now my 2010 f150, I bought one of those 3 outlet kits, and hardwired it with an add-a-fuse to a ignition controlled fuse spot. I mounted the outlets inside the center console with velcro, that allows you to run the various power cords under the console, out of sight, out of mind. Drill a hole in the inside bottom back wall big enough to feed the cigarette lighter adapter through. Just use a volt meter to figure out which fuses are on only when the ignition is on. I believe I used the power windows fuse? Works like a champ. I also had a battery buddy. It disconnects the battery if volts drops below 12.5V or so. Push the brake pedal and it reconnects. Problem with that is you lose your memory settings on radio and so on. Boooooo, I cannot believe that Ford still has not fixed this problem, or at least allow it to be user changeable via the system setup.
Old 09-25-2010, 01:03 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
Just did the same in my new 06 F250 Lariat. Gets kind of tiring doing the same mod over and over and over....
Old 09-26-2010, 08:48 AM
chuck s's Avatar
chuck s
chuck s is offline
Darn!
I'm still hoping for that post that says something like "Move the wire from terminal X to terminal Y."
-- Chuck
Old 09-26-2010, 11:32 AM
nfntruth's Avatar
nfntruth
nfntruth is offline
Originally Posted by chuck s
Darn!
-- Chuck
Hmmm, nope, not that I know of, I still think Ford should offer it as an option via the system controls menu.
Old 09-26-2010, 02:57 PM
chuck s's Avatar
chuck s
chuck s is offline
No one has the wiring diagram? I'd think the outlets could be moved to another point in the fuse/relay block. I'm thinking of moving the outlets to the Trailer Battery Charge connector -- if I knew where the outlet and charge connector were.
Well at least it's not as bad as my olde classic '58 Alfa Romeo Spyder that I had in college! In that car the tube type radio was wired straight to the battery for some reason. Turn the radio down to hear something and it's dead within minutes after shutting the engine down. I taught my girl friends how to bump start too many times. No, I pushed, they worked the clutch! Was easy to fix once I figured out what was causing it.
My Expedition and Explorer can usually get thru two days before the Priority Start shuts the system down.
-- Chuck
Old 09-26-2010, 04:25 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
-- Chuck
A deep cycle Optima helps, thats what I have in the trucks except the F250, 500 bucks for two batteries is a little much for the tow rig.
Nimrod
2017+ Super Duty
17
12-05-2020 08:41 PM
Indslpwr04
2009 - 2014 F150
08-20-2016 07:34 AM
Chuck's First Ford
1999 to 2016 Super Duty
18
10-28-2015 07:29 PM
clr0gers
1947 and Older Ford Trucks
07-07-2014 08:26 AM
chemoman
10-03-2011 02:17 PM
Quick Reply: Changing 12v outlets to Ignition-Switched?
