Jacks 65 Build
Old 03-29-2012, 02:54 PM
schoo's Avatar
schoo
schoo is offline
looks great, what kind of soda blaster/sand blaster was that?
just today took a 64 cab that had no rust on the bottom to get crushed
  #32
Old 03-29-2012, 03:29 PM
Jacks 65's Avatar
Jacks 65
Jacks 65 is offline
The soda blaster is from harbor freight, it does a pretty decent job, other than clogging a bit at times...I was surprised at how well it removed 47 yr old undercoating
  #33
Old 03-30-2012, 03:29 AM
fordpt's Avatar
fordpt
fordpt is offline
Sorry about your arm. When I broke my right arm (ladder broke) Doctor told me to keep working, do as much as I could and when it hurts, just do more with other arm. Same response when I had carpal tunnel surgery. So I did this. http://www.tractorshed.com/gallery/tphotos/a38169.jpg
  #34
Old 03-30-2012, 09:57 AM
Jacks 65's Avatar
Jacks 65
Jacks 65 is offline
That's awesome! I am trying to keep it moving, but the swelling is still pretty substantial at this point...my doc told me the same thing yours did. My break is in the elbow though, I guess when I said arm it was pretty in general of me.
  #35
Old 03-30-2012, 03:29 PM
fordpt's Avatar
fordpt
fordpt is offline
Swelling, inflammation and pain, Advil or Equate liquid gels work for me.
  #36
Old 03-30-2012, 04:02 PM
Jacks 65's Avatar
Jacks 65
Jacks 65 is offline
Right now they have me on prescription anti inflammatories, and pain meds...good stuff, makes me a little light headed though
  #37
Old 03-30-2012, 06:40 PM
fordpt's Avatar
fordpt
fordpt is offline
Better to put up with some pain and swelling using over the counter meds than to use addictive prescription meds, they should be called brain medicine because all it does is trick your brain. You have to take more and more, they stop working, take even more. Not good. I lost my twin brother at age 39 to pain meds. I used them for when I had carpal tunnel surgery.
  #38
Old 03-30-2012, 07:21 PM
andgott's Avatar
andgott
andgott is offline
Looking good!
How hard was it to modify the steering column? The one in my '66 is out of a 70 something, and a little longer than it should be. It works, but doesn't leave a lot of room for the driver. I guess my options are to go on a diet, or shorten the column...
-Andrew
  #39
Old 03-30-2012, 08:33 PM
Jacks 65's Avatar
Jacks 65
Jacks 65 is offline
Originally Posted by andgott
Looking good!
-Andrew
It was fairly simple to shorten the column housing. I didn't shorten the shaft itself because I had a shaft that was correct length. Fordification.com has a good write up on shortening everything.
How to Shorten Your Manual-Steering Column - FORDification.com
  #40
Old 03-31-2012, 09:28 AM
schoo's Avatar
schoo
schoo is offline
jack it loks like you did not pull off the cross members or other riveted mounts
to clean rust under?
my frame is lightly rusted but what about in between these areas?
roy
  #41
Old 03-31-2012, 10:12 AM
Jacks 65's Avatar
Jacks 65
Jacks 65 is offline
roy
Roy, you are correct...I didn't remove any crossmembers...hopefully it doesn't come back and bite me. This was a Kansas truck, and I now live in the high desert in Reno, and the truck will be garaged for the rest of its life...hopefully the rust converter seeped under the crossmember to help me out but probably not.
  #42
Old 04-01-2012, 10:07 AM
schoo's Avatar
schoo
schoo is offline
the reason i ask is i'm a way's behind you in time and skill and about to remove the cab on mine. and their was alot of dirt between members that blasted out
with pressure washer mine still has paint in most places. just thinking how far to go 0n this?
roy
  #43
Old 04-01-2012, 12:18 PM
Jacks 65's Avatar
Jacks 65
Jacks 65 is offline
Roy, I don't have much skill, just not afraid to jump in and tear this truck apart. In fact I'm a bit scared to put it back together lol. I think how far you go is up to you. Sometimes I ish I hadn't gone this far, I've been working on this truck since 2007, and havent drove it since then either. Do what you feel comfortable doing, and most importantly enjoy what your doing. I've torn this truck down so far that at times I've lost interest in getting work done on it, because I don't see light at the end of the tunnel. But that is me, not everyone feels the same once it's torn down.
  #44
Old 04-01-2012, 07:47 PM
schoo's Avatar
schoo
schoo is offline
i'm thinking the same thing i've worked on a # of ford vehicles 1960 falcon was first so i'v seen these parts before did a lot of work on this truck in the late 80's
but now i'v got it to the point of taking the cab off
yea that is my next problem how to disconnect the sterring column?
no rag joint just a clamp
roy
  #45
Old 04-21-2012, 12:19 AM
Jacks 65's Avatar
Jacks 65
Jacks 65 is offline
Sorry to hear about your brother, my sister is also struggling with issues of addiction to pain meds...thankfully I wasn't on them long!
Hopefully I will be able to get back to work on the truck soon
Quick Reply: Jacks 65 Build
